Old 21-04-2012, 11:25 AM   #1
raised by monkeys
raised by monkeys's Avatar
Default power steering fouling
I have a leak at the bolt at the top of the hose where it threads into the pump seal. Is there meant to be an O-ring there?
I think it is a different hose to the 6cyl also.
Can anyone confirm this?
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
Old 21-04-2012, 11:36 AM   #2
raised by monkeys
Default Re: power steering fouling
by the way, whats actually happened is that i have had a mad leak and running out of fluid. Ive just been topping it up over the last week or so until i had time to get to it. The leak has reduced but im not getting any fluid to the steering now, but theres still a slow leak at the top bolt but the pump still has plenty of fluid in it.
Maybe i ive damaged something with on going use while low on fluid?
cheers
Shaun
Current
Previous
Old 21-04-2012, 11:41 AM   #3
Day-mow
rexnet
Day-mow's Avatar
Has the pump ever been dry?
Pretty sure it's just replace the O-ring and that's a good start.
Mattered also a switch in the PS rack. It's possible that may have died and that's the issue.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 21-04-2012, 12:17 PM   #4
raised by monkeys
a switch? to allow for the flow of fluid?
That nut is different to the one on your car too bro
cheers
Shaun
Current
Previous
Old 21-04-2012, 12:21 PM   #5
raised by monkeys
dunno if its been bone dry, but its been close when the leak was at its worst
cheers
Shaun
Current
Previous
Old 21-04-2012, 12:44 PM   #6
Franco Cozzo
Franco Cozzo's Avatar
My EL is doing the same thing, the O ring wears out, I don't think you can replace it.
Repco sells a replacement hose, its a common thing, also have a look at the Alternator, if you leave it too long, they leak into the alternator and it screws the slip rings, if you get a new alternator done, they won't warrant it unless you also replace the power steering hose.
If its a V8 this might not apply.
Old 21-04-2012, 12:51 PM   #7
raised by monkeys
yup, alternator is on the other side.
cheers
Shaun
Current
Previous
Old 21-04-2012, 02:02 PM   #8
raised by monkeys
just unscrewed the hose again and as i was turning, there was a build up of pressure and fluid was spitting out the more i turned. I took it off and started it up to release the pressure (cleaned up the mess lol) and put the hose back on. There is no fluid getting to the steering system. So im guessing its either a blockage in the hose or the pump. Not playing with it this weekend. Its my only car, i live on my own and ive got no way of getting parts until pay day. Ill go to the mechanics on monday with it and get him to have a squiz for me. It never ends.
cheers
Shaun
Current
Previous
Old 21-04-2012, 02:40 PM   #9
mik
mik's Avatar
the joys of motoring mate, i just bought myself a new toy and after an hour and a half drive home it`s smelling of petrol fumes :(, what`s that old saying anything with wheels or bristols ......you know they are going to cause you some grief .
Old 21-04-2012, 03:04 PM   #10
irdonn
irdonn's Avatar
If you're thinking of hanging on to it for a while, give Enzed a call. They should be able to make you up something that's a lot better than the current Ford set up. Not sure on price though.
06/01 AUII XR8
irdonn is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2012, 04:21 PM   #11
b2tf
not here much anymore
b2tf's Avatar
Shaun check with Ford as if i remember correctly they actually changed the design of the connection due to this, I have a feeling it might have been after Series I but would still be worth asking the question.
2024 F150 XLT
Old 21-04-2012, 08:14 PM   #12
Day-mow
rexnet
Day-mow's Avatar
It would be pirtek here and it's pretty expensive. The switch in the PS Rack has something to do with how it all works. And I know when it fails it effects lubrication. But sounds like your high pressure pump hose is blocked. Try spencer gulf bearings for one. If not maybe Whyalla brake and clutch and then repco/auto pro. But it's not going to be cheap.
Old 22-04-2012, 01:02 PM   #13
raised by monkeys
my money is on the hose
cheers
Shaun
Current
Previous
