Beautiful in Black
My missus has a 2008 Focus & we've found the wheel nuts have got these plastic caps (presumably to convert from imperial to metric?) which have started coming off (as shown at 9 o'clock & 4 o'clock in the photo below)
![]() I showed it to the local Ford dealer & he'd obviously seen it before but said it was due to the use of rattle guns (hello, I've never seen a tyre store not use rattle guns ... and yes, they use them too) and not covered under warranty. A quoted price at $25 per nut (WTF!!!) to replace them with the same crap doesn't excite me, so can anyone help with where I can get some aftermarket wheel nuts/lugs to suit, and at some more realistic prices? Any assistance would be appreciated.
Current Ride:
FG FPV F6 Ute #308 My Ford heritige prior to the FPV: BA MkII Classic | AUII S Pack | EL Futura |EFII Classic XF Fairmont Ghia | XE S Pack |
Where to next??
I think they are just cosmetic.....
Come off due to rattle guns?? Doubt it. I would just try and find a non genuine set and do the whole car over. Would be cheaper than 1 genuine one from Ford I would imagine. Before putting them on, clean the wheel nuts really good and put a thin bead of Blu-tac on each stud to hold them in place. As I said, I'm pretty certain they are purely cosmetic. If you were really particular about them you could also get aftermarket wheel lugs that have the chrome looking nut built in... but make sure they match your wheel brace or you won't be able to change a tyre!
___________________________ I've been around the world a couple of times or maybe more....... Last edited by Yellow_Festiva; 10-05-2012 at 07:34 PM. |
Mine have done the same thing, probably 4 or 5, also these wheel nuts are made out of wet paper bags, I managed to shear one badly with just a cross brace trying to undo it.
Also, they have a really large taper on the other side of the nut, I couldn't find anything with the same size taper. |
yeah pretty sure they're purely cosmetic
going purely from memory with them on it needs a 19MM socket and without it's 18MM and a real pain to get them on/off i've left them permanently off and it doesn't look noticeably worse for it |
I found these ones on eBay from the UK, you may need to remove one of yours and check that they are definitely tapered and match with the size listed but they should do the trick
![]() http://www.ebay.com.au/itm/20-x-ALLO...-/220910728444 |
#6 | |||
Beautiful in Black
and btw you've just saved me a packet (& a bit of grief from the spouse) thx mate ... love to buy you a beer sometime if ur ever in the area, cheers ![]()
Current Ride:
Those are exactly it.
#8 | |||
#9 | |||
They look to be slightly narrower at the overall width. I don't have calipers to measure the factory wheel nuts, but holding the factory nuts on a ruler, they look to be closer to 27-28mm wide. The taper looks ok though. |
#10 | |||
They are cosmetic only, rattle guns do play a part in the caps coming off.
The caps are only pressed on... |
#12 | |||
FORD FOCUS Titanium Sedan with Sports Executive Pack in Midnight Sky GDI Going somewhere isn't why you drive, driving is why you go |
#13 | ||
I've seen experienced techs and wheel/tyre fitters do it too.
I have a ![]() Even worse when they get used to undo/do up lock nuts! ![]() ![]() ![]() |
#14 | ||
A tip for Ebay UK. Be persistent. A lot of the sellers dont want to sell to OZ. Just press them for why? Our money is just as good.
But ask them to use Royal Mail small packets service. Cheap as, and like OZ post, they have a tonne of standard bags and boxes, that you can check up on the price for. They can also affix a sticker to a non standard box. I've never had an issue, a part from one that took 12 weeks to get here! Even had a rear bumper insert sent down in a tube once. (over 1.2m) No issues. - reminds me, I must get that on the car....
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR |
