16-12-2008, 07:47 AM | #1 | ||
true blue
Just finished the rebuild on my tranny, only to find out that there is no Castrol TQ95 immediate available in South Africa!!. When one is servicing the tranny with the filter kit from Ford (part no. ED 7B000 KTF), it says in the instructions that other oils are available as-well. For Shell this should be ATF XTR, for BP Autran LE and a few more were I can choose from. (If I wish to do that). I did a Google search regarding Castrol TQ95 and more than once I had to read that Castrol TQ95 is specially developed for the BTR gearboxes used on Falcons, and that one should only use Castrol TQ95. So say some others manufacturers about their ATF oil. What I like to hear from you is, are some of you using other brands safely so it can replace Castrol TQ95?. What makes this oil so special, while we got higher rated oils available today (Dexron level III). Somebody using Castrol TQ Dexron III? It's available over here.
16-12-2008, 10:03 AM | #2 | ||
dex3 will kill the trans. so unless you want to pull it out again (which i doubt) don't even consider it...
you can use any brand equivalent of TQ95. Valvoline make one, as do quite a few companies. it doesn't have to be castrol. a couple of members on here are taxi operators. they use whatever oil is cheapest at the time and still get around 350000km with regular servicing of the autos. whatever you do MAKE SURE YOU DON'T USE DEX3. |
16-12-2008, 10:07 AM | #3 | ||
No you cant use dexron III, and you cant use normal ATF, only the XTR version. The oil for the BTR transmissions is specifically designed for them, it has a lot of anti foaming agents that dexron III etc doesn't, all i can suggest is to get some air freighted over to yourself.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
16-12-2008, 02:41 PM | #5 | ||
From my investigations on the differences in TQ-95 it has extra anti wear additives over normal dexron fluid to help the planetary gears from wearing.
16-12-2008, 08:38 PM | #6 | ||
valvoline also make an oil called MAXLIFE that is ok to use in ford boxes...
16-12-2008, 08:56 PM | #7 | ||
IWCMOGTVM Club Supporter
What rating is Transmax Z and is it ok with the BTR or should only be used in the T5?
Daniel |
16-12-2008, 09:06 PM | #8 | ||
Funny you mention that ..Transmax Z is actually a synthetic version to Dexron 3 specs.. I'm sure i'd seen somewhere guys using that but haven't been able to find out for sure .
17-12-2008, 02:05 AM | #9 | ||
i'd be staying clear of any tranny fluid that you haven't pers0nally seen appr0ved to suit, anyway as i stated BTR trans fluids of all different brands have extra anti foaming agents in them, cause the BTR trans easily foam's up the transmission fluid, causing airated fluid giving insufficient lubrication and pressure. I have seen dexron 3 put into btr's before and they don't last long, like a couple hundred km's.
Im sure gregaust is also correct in saying that it has extra anti wear additives. Dexron 2 is actually less foaming than dexron 3.
17-12-2008, 03:38 AM | #10 | ||
true blue
Thanks for all the advise. Today is reconciliation-day here in South Africa, so I'm trying to figure out what oil to use. Options are few, looks like the Focus is going to be the summers holiday transport. Will keep you posted.
Big thanks and a Merry Christmas and a Happy New Year to all. This website is absolutely fabulous. Cheers Max |
21-08-2012, 06:21 PM | #11 | ||
What about using BTR Conversion Formula mixed with Dextron?
Thanks |
23-08-2012, 10:41 AM | #12 | ||
66 Mustang
Sanggyong autos also use TQ95 so if sanggyong vehicles are available over there, look at what is recommended there for them.
23-08-2012, 10:55 AM | #13 | ||
Id has a guess that after 4 years, he may have already found some oil.
