Old 18-12-2012, 11:36 PM   #1
xr6tjet
[AUT-747]
xr6tjet's Avatar
Default AU Falcon Bouncy Ride
Hey,
So i've got a set of compressed springs in the rear of my AU and the ride is just extremely bouncy. Its unbearable for passengers. I know its bump stops but I'm starting to think my shockers arn't really that short, as the place I bought them from seemed dodge. They are apparently KYB Shortened shocks. IS there anything I can do to make the ride slightly better?
Cheers, Alex.
xr6tjet is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2012, 12:01 AM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: AU Falcon Bouncy Ride
With how low your car is, I wouldn't be surprised if its the shocks. Probably slowly leaking from being on near no travel most of their life.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2012, 01:26 AM   #3
xr6tjet
[AUT-747]
xr6tjet's Avatar
I know but, they just have sucked from the beginning. Even with my old springs which were about 10mm higher then the ones I have now. They sucked then and they suck now. There must be something I can do to make the ride better... ?
Old 19-12-2012, 01:01 PM   #4
EL.50
Just cruisin'
EL.50's Avatar
There is...air bags
EL.50 is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2012, 01:06 PM   #5
EFFalcon
Last warning
EFFalcon's Avatar
won't ride better with airbags.
get some *GOOD* shocks in the rear.
adjustable koni's or something, will be firm, but should get rid of the bounce.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 19-12-2012, 01:18 PM   #6
EL.50
Just cruisin'
EL.50's Avatar
Will ride better with air bags when he raises it a bit to drive around, then drops it when he parks
Old 19-12-2012, 01:49 PM   #7
Stagg
Stagg's Avatar
Had that happen to me the other day, is your AU IRS? is the rear bouncy instead of the front? My rear upper shock mounts had eaten themselves and I had the same problem and after researching a lot of people had the same problem. Check behind the back seats where the shock mounts are bolted.
There is a member here (forgot his name) who modifies upper shock mounts that means you don't have to replace them. But yeah check your shock mounts first!
DAS IT MANE
Stagg is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2012, 08:04 PM   #8
EL.50
Just cruisin'
EL.50's Avatar
His is non IRS, its very low though
Old 20-12-2012, 01:57 AM   #9
xr6tjet
[AUT-747]
xr6tjet's Avatar
Non-IRS man. Its quite low but I really need to fix the ride somehow. Koni adjustables may do the trick? The ride has got to improve somehow!
Old 20-12-2012, 10:27 AM   #10
Stagg
Stagg's Avatar
Was it always bouncy? was there something that was changed recently that caused the ride to be extra bouncy?
I have Koni adjustable yellows in mine and they sure do the trick. Sticks to the road
DAS IT MANE
Old 20-12-2012, 11:27 AM   #11
MAD
Petro-sexual
MAD's Avatar
There's always a trade-off when you go that low.
I'm not even sure koni's will fix it. I've seen people make custom upper shock mounts that are taller to get the shock operating in a better range.
I'm surprised you're not having issues with your tail-shaft at that height.
EL Fairmont Ghia - Manual - Supercharged
- The Story
MAD is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2012, 01:13 AM   #12
xr6tjet
[AUT-747]
xr6tjet's Avatar
Another fella who saw my suspension told me to get a larger shock hat for more travel. I've been thinking about doing something like this! Or an IRS conversion possibly.
Old 21-12-2012, 01:52 AM   #13
xr6tjet
[AUT-747]
xr6tjet's Avatar
anybody extended their shock hats, if so. How ?
Old 22-12-2012, 06:06 PM   #14
XRGhia
meh.
XRGhia's Avatar
Just get spacers made up to space the hat up.
Old 23-12-2012, 05:24 PM   #15
robbyj
Rob
robbyj's Avatar
Is it a show car or a daily. either bag it or raise it.
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2012, 12:21 AM   #16
mik
mik's Avatar
yeah bags are pretty good, gotem on my old ls400, fully independent adjustable height control of front and rear axle height.
Old 31-12-2012, 03:19 PM   #17
xr6tjet
[AUT-747]
xr6tjet's Avatar
I want bags but the price is just insane for the rears :( Can't justify that much. I need to see if I can organise something to fix it!
