Old 06-01-2006, 01:22 AM   #1
philg
Default Changing Leads
Just got some Top Gun ignition leads for my AU 6. But how do you get to the coil pack to change them?
philg is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 03:47 AM   #2
blackers10
blackers10's Avatar
jack the car up and bend ur arm in some funky way to undo the old ones and put on the new 1s..
my mate reccomends doing them 1 at a time.. and i agree coz i did mine my self(he works for toyota @ redcliffe and does a few fords when the ford dealership at brendale is overbooked(they send them up)
thats also how mr Ford does it.. as his sisters bf worked at a ford dealer as mechanic and thats how they do it.. its stupid but its how it is..
have fun
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 07:38 AM   #3
mattbl
mattbl's Avatar
I managed to replace mine from the top with the aid of a torch. I've got small hands though.
2006 BF Egas XR6 Ute. Bone stock - Sorry Fellas I've had a set of King Springs in the garage for 12 months who knows when I'll get around to putting them on :
mattbl is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 08:10 AM   #4
rob_liss_lms10
rob_liss_lms10's Avatar
take out the air box and it's not to bad,still fiddly though.Did mine last wkend.
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD
rob_liss_lms10 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 09:57 AM   #5
JC
Miami Pilot
JC's Avatar
mattbl & rob_liss_lms10 have the right way to do it for the backyard mechanic. It is a pain though - allow about 1.5 hrs. The V8 takes about 2.5 hours!
Ford Performance Club ACT
Old 17-01-2006, 05:05 PM   #6
gus351
Posts: n/a
take air box out
Old 17-01-2006, 05:08 PM   #7
Racecraft
they call me Tibbo
Racecraft's Avatar
its easier if you get someone to feed the leads thru one by one.
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 06:38 PM   #8
Mechan1k
Mechan1k's Avatar
2 people working on it makes it easier.
easier if you are anorexic as well.
Still a PITA job to do.
definitely do one at a time .. or there could be tears ... and a very bad idle
Old 17-01-2006, 07:20 PM   #9
Stav
Smile
Stav's Avatar
It takes me 1/2 an hour to change my leads. You need a torch though to spot the numbers on the coil pack which corresponds with lead.Remove air filter.Make sure car is cold.Use your arm and slide it between air box and intake manifold.Once you slide your arm towards the coil pack remove them one by one and you should be fine.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 17-01-2006, 08:03 PM   #10
DanXR6T
Eat more peanuts....
DanXR6T's Avatar
One at a time is a pain in the butt
1 - 2 - 3 - 4 - 5 - 6
Front of Car - Engine - Rear of Car
1 - 2 - 3
6 - 5 - 4
That should make sense.
Also if the originals are OEM ones, there will probably be a massive cable around the coil pack which you need to cut off.
Dan..
'04 Falcon XR6T Ute, Envi, K&N filter, F6 Intake, Twin 2.5" exhaust...
Formerly owned:
'99 AU Falcon Ute
'88 EA Falcon GL
DanXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 12:28 PM   #11
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
As everyone has stated PITA Job, and Axeman82 just stated, If still Original, there will be a veyr thick Cable Tie under the coil pack, up and over the leads to ensure they dont move/come off. I had mine up on ramps and did them from underneath, (easiest way) 1 at a time. Then at the end shoved my hand down from the top to just ensure they were all on nice and tight. Was going to put another Cable tie over them but it got put in the Too Hard Basket.
Its pretty easy to do when you have the numbers as stated above but they are staggered.
i.e. Looking from Top With Left Being The Front Of The Car
(From Memory)
- - 1 - 2 - 3
6 - 5 - 4
But may be the other way i.e.
1 - 2 - 3
- - 6 - 5 - 4
You will know when you see it.
Have fun.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
