Old 23-10-2013, 09:45 PM   #61
marcyeo
Regular member
marcyeo's Avatar
Default Re: Drag racing tips
Originally Posted by King Dribble View Post
Hey Marceo, are you going to the Mackay track? Its the closest.
Hey mate, I really wanted to, but I'm shifting jobs next year and will be in Ipswich, so was thinking of getting to the Queensland Raceway instead... would have loved some time to drive down to Mackay though.
CURRENT
2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance.
OLD
2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw
marcyeo is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2013, 09:12 PM   #62
pajoda
pajoda's Avatar
Bumping thread, taking the Focus ST out to WSID tomorrow night, first timer, really looking forward to it. Not sure on tyre pressure, or ESC sport mode or off completely. Will play around a bit and see how I go. Any front wheel drive experience here to offer advice?
2018 Ford Focus RS
pajoda is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2014, 03:36 PM   #63
marcyeo
Regular member
marcyeo's Avatar
Got the F6 written off and got myself a GT instead - I took the F6 to the drags last time and from all the tips here was stalling to about 2000rpm or so to launch. I wanna see what the stock GT will do down the 1/4 mile before a tune sometime next year.
From your experience, is this the same with the V8 or would a lower stall do? Any other differences in launching the V8 vs the turbo 6 would be appreciated..
CURRENT
OLD
Old 04-08-2014, 02:04 AM   #64
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Cat600 should be able to give you some tips.
But it's going to depend on the track prep and your tyres. Stock tune would have driveline protection / torque management I am guessing so that would limit your ability to launch.
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2014, 02:12 AM   #65
Giant
Giant's Avatar
Remove the rear wheel, move the passenger seat all the way forward and wind it forward. Play with tyre pressure, throttle and brake control. Limit boost at the tree.
Old 04-08-2014, 02:26 AM   #66
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Stock converter you're often better off with stepping off the brake and then onto the gas (kinda like down on one as you are releasing the other, because the converter is so tight it will blow the tyres off if you load it up too hard, but preloading an IRS is the way to go fast so that's why I started off with a loose high stall on the V8 (4200 rpm)... Seems to work just gotta get the suspension setup right now
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2014, 07:09 AM   #67
marcyeo
Regular member
marcyeo's Avatar
Ok so I don't really even need to stall/rev it up any - just modulate the right foot? (Sorry shoulda mentioned it's an auto).
CURRENT
OLD
