Old 02-03-2015, 08:30 PM   #1
mcfly94
mcfly94's Avatar
Default Need AU2 v8 ecu pinout wiring diagram.
Trying to find out which wire is for vss.
Not white as that was injector #2
And thats the only white cable.
Theres a white lb trace but thats not aff tech docs wiring diagram
Need it for my speedo corrector
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2015, 09:25 PM   #2
Spurious
Default Re: Need AU2 v8 ecu pinout wiring diagram.
I just took photos of the diagrams in my Max Ellery manual.
Speed sensor wire is labelled as "W", same as injector no:2
Probably not helpful 'eh?
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2015, 11:07 PM   #3
Jarry
Going with the X-Flow
Jarry's Avatar
Hi,
I've been looking at this myself recently after a diff swap. I've got the Fairlane/Ltd Factory Supplement for the NU1/DU1 series. Not sure if it applies to Series 2 though. Here's some info, I hope it helps...
The speedo transducer sends the signal to the instrument cluster. I'm pretty sure it passes through the big connector in the engine bay.
The diagram shows the Vehicle Speed Sensor (VSS) hall effect signal then goes from the instrument cluster to #58 on the PCM connector. The wire should be white, but this is the AU1 diagram. You might be able to confirm if you can get hold of a scopemeter (or try the poor man's method and switch your multimeter to AC voltage).
In Connector C-171 (that goes in the back of the instrument cluster) the "VSS-in" is position J2-17 (light blue/white wire #999) and "VSS-out" is in position J2-18 (white wire #999).
I think VSS-out splits after the connector, going to the cruise control module and the PCM.
So... I'm guessing you would splice the speedo healer in before the signal reaches the instrument cluster.
Jarry is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2015, 11:13 PM   #4
Jarry
Jarry's Avatar
If you're running 16" wheels, another option is to use the 23tooth black speedo cog and accept about 9% speedo error with the 3.9's.
Old 04-03-2015, 11:35 AM   #5
GasoLane
Former BTIKD
GasoLane's Avatar
At the top of the front page of the AU forum there is this............ Announcement: Wiring Diagrams - UPDATED Dec 2014
Follow your nose, it should be there.
