11-06-2015, 07:06 AM | #1 | ||
XR6T BA 2002
My R31 3.89 diff with 4 pinion VL turbo LSD is on its way
Had it built by Glenn in Dandenong ( vicmelboz differential ) Can someone please give me a guide on how to do the diff swap I have never done an IRS diff before Cheers
XR6T 2002 BA
11-06-2015, 07:13 PM | #2 | ||
XR6T BA 2002
anyone help
XR6T 2002 BA
11-06-2015, 07:39 PM | #3 | ||
So youve had this built all into an au housing?
if not youll have to pay someone to do that. But if all in au housing ready to go its pretty easy, remove spring assemblies, undo top control bolts to stub, undo tailshaft, remove half shafts, undo 3 bolts and its out, reverse the procedure.
12-06-2015, 07:33 AM | #4 | ||
XR6T BA 2002
Yes built into AU housing , all ready to install once it arrives
Thanks for the guide mate, Is there any other heads up like may need to replace anything through out the swap out? Any special tools that i may not have? etc cheers
XR6T 2002 BA
13-06-2015, 06:25 PM | #5 | ||
XR6T BA 2002
Need Help Please
Exhaust is out tailshaft will be out shortly how do i remove half shafts, where is the bolt for the remove spring assemblies,and top control bolts to stub, cheers
XR6T 2002 BA
13-06-2015, 06:36 PM | #6 | ||
crow bar gently or big tyre lever will pop the half shafts out
bolt is right at the bottom of the shock and inside the towers of the car, top lca bolt to stub is pretty clear to see, wont miss it.
13-06-2015, 08:35 PM | #7 | ||
XR6T BA 2002
Thanks for your help
Tail Shaft out abs sensors off shocks out 2 bolts rear of diff out 1 bolt under diff loose do i jam my massive screwdriver here as pictured to pop these half shafts
XR6T 2002 BA
13-06-2015, 09:01 PM | #8 | ||
XR6T BA 2002
can anyone help
XR6T 2002 BA
13-06-2015, 10:05 PM | #9 | ||
XR6T BA 2002
bump.............................................. ....
do i need to remove brakes and hubs or not
XR6T 2002 BA
14-06-2015, 01:46 AM | #10 | ||
Sounds like you need a workshop manual...
14-06-2015, 11:45 AM | #11 | ||
XR6T BA 2002
i do but thanks
XR6T 2002 BA
14-06-2015, 11:55 AM | #12 | ||
yes, undo and move the brake caliper to one side, undo the top and bottom bolts holding the hub upright and carefully leaver the drive shaft between axle and centre housing and with a little force it will pop loose.. pull the shafts out enough to clear the centre..
14-06-2015, 01:52 PM | #13 | |||
XR6T BA 2002
Thanks T-Man One side popped out, had to remove toe link on drivers but passenger wont budge and the bolt holding toe link in on sub frame fails on fuel tank so i cant get it out gonna need new upper and lower control arm bushes now and toe links
XR6T 2002 BA
14-06-2015, 02:01 PM | #15 | ||
XR6T BA 2002
XR6T 2002 BA
14-06-2015, 11:22 PM | #16 | ||
XR6T BA 2002
Got it, bashed it with hammer 3.9 diff in all back up except exhaust my procedure i did Crack wheel nuts Jack car + stands Take wheels off Undo cat back and remove Remove tail shaft but mark all points and locking nuts remove brake calipers and set aside on milk crate take off rear discs Remove Rear shocks and spring complete unit remove rear toe link on hub, its just one nut but your gonna have to keep nut on the end and bash it with a hammer up so it will pop out cause my were a pain and i don't know why and now i need new ones but anyway remove upper control arm bolt need breaker bar, beware of falling perished bush particles remove lower control arm need breaker bar , beware of falling perished bush particles get another milk crate ready and pull toward you the half shaft and then reach in and pull it out of diff, crow bar and screw driver did damage and wouldn't pop it Remove abs sensors Drain diff oil 2 bolts rear of diff remove get jack under diff with wood ready to drop 1 bolt under diff undo drag diff out on trolley jack
XR6T 2002 BA
