Old 22-02-2006, 08:41 PM   #1
GK
Walking with God
GK's Avatar
Default Stripped Wheel Nut!
I have one stripped wheel nut. The thread on the bolt looks almost salvagable, but the nut itself is trashed! How do I go about fixing it?
I was thinking that SuperCheap or Repco would have a kit, and I would use those locking grips to twist the old bolt out and screw the new one it. Then just apply the new nut! This sound about right?
GK
Old 22-02-2006, 08:56 PM   #2
OZFORDAU
OZFORDAU's Avatar
Post Lmao
GK
LOL, i was just at Ford today trying to take off the darn wheels cause they were really tight! But they could only losen one cause the wheel nut lock is bugggerd! The guy at Ford told me to go to Goodyear or a tyre place n get a new one they cost roughly about $15.
Simon
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2006, 09:00 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
front or rear? they just press in from behind
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2006, 09:04 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
you have to whack the stud with a drift. you may be able to do with without removing the disc . then the new stud will get hammered in from the inside of the hub outwards.
The studs come with tiny splines and the head is flat n larger.
no chance trying to twist it out sorry mate
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2006, 09:55 PM   #5
GK
Walking with God
GK's Avatar
Thanks for the replies fellas. I'll get it seen to this weekend.
GK
Old 22-02-2006, 11:30 PM   #6
Baboon_AU
Baboon_AU's Avatar
get a new set of nuts!! not hard
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
