01-04-2006, 07:31 PM | #1 | ||
the double din cd player in my au2 XR6 is being a ИИИИИ..everytime i burn an audio cd it wont load the cds properly it keep spitting the cds out and i have to keep putting em' back in until it reads it! does anyone have the same problem i have? its not the cds im using ive changed the brands like 3 times and they are good brands! i'm getting a new head unit soon but i still wanna no if its the actual cd player's themselves...
cheers.! |
01-04-2006, 07:37 PM | #2 | ||
If my memoery serves me, these head units are not CD-R compatible. If you are going to get another head unit soon it may be worth asking if it is compatible with CD-R's. Most modern units are now.
01-04-2006, 09:01 PM | #3 | ||
Forum Director
They do play cdr's, but are very finniky about it.
I find that when mine is spitting them back out, the best way to get it to accept them is to place the burned disk in the deck, then select the next disk before the deck spits it out. Sometimes you have to select back and forth between discs a couple of times before it will play. Overall, it's probably bloody easier to change the head unit if you want to regularly play cdr's :( |
01-04-2006, 09:48 PM | #4 | ||
If you use dedicated Audio CD-Rs, then you should find the problem goes away. I've never had a problem using burnt CDs in my AU1 or AU2 CD players.
01-04-2006, 10:20 PM | #5 | ||
Kuga TF Trend
I hvae a similar problem with my AUI Fairmont.
I always burn my audio discs at the lowest possible speed. I think it has to do with the "over burn protection" on a cd burner. In the days before this protection, if your computer could not keep up to speed with the burning of a cd, you would create a coaster. Now-a-days they actually stop the laser from burning, put a 2ms gap between the last lot of data and the new lot. Therefore if you create a cd at the lowest possible speed, the overburn protection will not be inititiated and your car cd player will love you for it. Give it a go and see if it makes a difference. Cheers Ty |
01-04-2006, 11:26 PM | #6 | ||
cheers pplz!
02-04-2006, 02:13 AM | #7 | |||
Fantastic Plastic
I use cheap'o brand cd-r's , Xlogic 700mb/80min cd-r's ( get them from big w / kmart ) , no dramas with them at all , providing you don't allow overburn and stuff like 83 minutes of music on them ! - and yes it can be done with some burning software , so check ya settings . .gl ..just my 2 cents ;)
------------------------------------------------------------ :eclipsee_ Last edited by XR6-VCT-2000; 02-04-2006 at 02:23 AM. |
02-04-2006, 02:58 PM | #8 | ||
my au headunit before i changed it never spat out any burnt disc.
02-04-2006, 05:20 PM | #9 | ||
Ive had two au2 work utes and the first one played cdrs no prob it had 40000 kms on the odometer,the second ute although identicle had 130000 ks and kept spitting out exactly the same cds,although after a couple of goes they would play.
