31-05-2011, 04:00 PM | #1 | ||
not here much anymore
Purpose of this thread is to compile all the part numbers for the various common parts the Windsors use. Talking things like the Cam Position Sensor etc.
If you have purchased a part, please post it up using the following format: Part Name (what it is) Part Number (from the supplier you got it from) Supplier (where you got it) Price (if you prefer not to say that's ok) Example: K&N Panel Filter to suit AU V8 Airbox P/N KN33-2015 Supplier - Autobarn Price - $50 I will add a couple I know of but if we all pitch in we should be able to create a handy list.
2024 F150 XLT
31-05-2011, 04:08 PM | #2 | ||
Yella Terra 'Street Terra' Adjustable Roller Rockers - 1.72:1 Ratio
PN: ST2027 Supplier: Yella Terra direct or any good auto store Price: $? Crow Cams Valve Springs to suit GT40P Heads PN: 7738-16 Supplier: Crow direct or any good auto store Price: $unsure - been a while since I bought some NOTE: Suits cams UP TO .550 lift MSD Ignition Coil Packs to suit AU V8 (direct fit) PN: MSD8241 (you need 2) Supplier: Most good auto stores, summit online etc. Price: $varies on supplier but you should get change out of $300 ARP Header bolts - replaces the standard hex key bolts on the standard headers and can also be used to fit aftermarket ones PN: ARP-100-1202 - pack of 16 Supplier: Most good auto stores, summit online etc Price: varies but about $30 or so
2024 F150 XLT
31-05-2011, 10:44 PM | #3 | ||
Replacement Camshaft Synchroniser to suit AU V8
PN: STANDARD MOTOR PRODUCTS Part # PC350 Supplier: Rock Auto Parts www.rockauto.com Price: will vary on AU$ strength Replacement MAF to suit AU V8 PN: MOTORCRAFT Part # AFLS155 Supplier: Rock Auto Parts www.rockauto.com Price: will vary on AU$ strength NOTE: Check the application as MAF's differ between series and XR/non XR Throttle Position Sensor to suit AU V8 PN: DELPHI Part # SS10387 Supplier: Rock Auto Parts www.rockauto.com Price: will vary on AU$ strength Spark plugs to suit AU V8 PN: NGK BPR6EFS13 or NGK TR55IX (Iridium) Supplier: Most good auto stores Price: Around $4-5 per plug, iridiums closer to $20 per plug NOTE: NGK recommend the Iridium ONLY, the BPR6EFS13 is actually for the Holden 304 V8 but will work quite well in an AU V8 and is cheaper than the Iridiums. I'm using BPR6EFS13 in an AU3 XR8.
2024 F150 XLT
01-06-2011, 12:56 AM | #4 | ||
Sales Representative
AU P/S Pump Top Hose Connector
PN: FO-BA3F656B Supplier: Genuine Ford Price: $11.88 RRP Note: OEM Desc - CONNECTOR PWR STRG AU P/S Pump Top Hose Connector O'Ring PN: FO-388898S Supplier: Genuine Ford Price: $6.94 RRP Note: OEM Desc - SEAL O-RING
01-06-2011, 05:49 PM | #5 | |||
5.6L x 2 pilot
02-06-2011, 06:48 PM | #6 | ||
does anyone have any part numbers for extractors I wanna finish off my exhaust and would like some part numbers on extractors.
Mines a series 1.5 late dec 99 au1 xr8 ute so unsure which heads i'm runnig |
04-06-2011, 10:11 AM | #7 | |||
2024 F150 XLT
04-06-2011, 11:43 AM | #8 | ||
5.6L x 2 pilot
Pacemaker - PH4000
Hurricane - HU354STM To be confirmed - these were part number supplied as a part of a quote as idea as to costs of AU V8 exhaust headers. Stu
02-12-2020, 12:33 PM | #9 | ||
If anyone is chasing passenger airbag clips which are now obsolete, i have some sets of 4 for $50. Ford number AU F04B26A.
