Hi All, Happy New Year to everyone. 2015 mondeo trend wagon when and how to use DPF cleaner? Noel.
Hi Noel
Happy New Year, please correct me if I am wrong but you can’t use a dpf cleaner as such. You have to take it into a workshop to clean it. I have also been told if you regularly take your car out on the freeway for about 30 mins it keeps your dpf in good shape Cheers Gabe Sent from my iPhone using Tapatalk |
Thanks for that Gabe.
drive it hard and it will burn off itself. If it still shows blocked, then the dealer can force a burn. If it's burnt but full of ash then I'm afraid a replacement will be needed.
Thanks Simon, its not showing anything at the moment was trying to catch it before it did. Noel
Option 1 if you have a copy of forscan and the OBDlink / EELM327 you can run the program yourself. Not overly complicated to run through the menus and forscan has a link that advises users.
Option 2 is ongoing preventative option is to drop this in your fuel tank every so often - see link: https://www.liquimoly.com.au/2729-di...lter-anti-clog Option 3 if you are based in Melbourne is I have a contact head mechanic from Ford that operates on the side. He pressure washes these without the need to replace them. They clog up if you don't allow them to heat up often enough. Hope this helps |
Thanks Mourati, will give opt2 a try. Noel
Hi Mourati, sent a PM but it didn't go through. The bloke in option 3 is that the one you sent a while back in Glenroy? Noel
