You guys know that Iam new to this and this is probably normal but when I turn the heater on (XR8 s3) the settings other than recycle and screen I hear what sounds like a shhhhhhh sound, it's not that loud but a bit irritating. The AC is off. This is not the fan, when I turn the knob to screen it stops, same for recycle. When I turn the car off it continues for a couple seconds then decrease and stops, sounds kinda like a ballon hissing down. Is this normal? If so what is it, if not what is it.
Vacuum hoses. You will probably find one is loose/split. Time for a dash rebuild
#3 | |||
Formally Kia Chaser
Once you take the dash apart and look at the back of the air flow knob, it has a heap of vaume hoses coming from it. The heater turn knob also has 2 hoses too. So unless you know the route of every hose and pipe in the knob assembly, it's hard to say why it does it on one setting and not the other.
It sounds like a vac. hose, but could be the selector knob assembly too....
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
I think taking the dash apart is beyond me, I'll just put up with it. It's not that loud and with radio on you'll never hear it! That will have to be my fix I think
Walking with God
The noise doesn't neccessarily mean a hose is split, there is vacuum noise when you turn the dial from one setting to another. Happens in my cars all the time and there's no loss of performance in the heater/cooler controls.
If your heater etc is working ok, I wouldn't worry about it. Noises can get very irritating though can't they? All the best with it. GK
i had the exact same prob when i bought my SR all i did was kept changing those setting like full cold, top fan speed, different flows and i managed to get something right but now it doesnt do it...dont no why but just keep fidling im sure you'll find it
FalconSR
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
Thanks guys, Iam sure it wasn't happening yesterday. GK, everything works fine, noise is a bit of an irritant but if I have it on screen no noise. FALCONSR I try what you did and see if it works. I did smell intially an odd smell coming from it, not refridgerant but something similar, that's stopped now.
I can sympathise with you. I get an annoying noise every time i press the accelerator. Sound of a 6 cyl
windsor user
my parents' au fairmont makes that sound almost every time its shut off after you've used the climate .... ive got no idea what it is but there is no issue with the climate system.... ive been driving it around all this week ( diff broken in mine:P) and the system works just fine
Giddy up.
Mine does this too, I think it's just normal.
#12 | |||
#13 | ||
Fantastic Plastic
Mine was doing the 'shhhhhhh' noise with the heater on the feet before i pulled apart the dash to change the lights in the clock and cfp. I found a few of the small clear rubber hose couplings that connect the vac hoses to the controls on the cfp were half hanging off ( they were still connected but needed pushing on firmer ) . Big improvement , no more noise
------------------------------------------------------------ :eclipsee_ |
#14 | ||
Giddy up.
Mine does not make this sound all the time, only when the fan has been on full and you then turn it down, or move the direction off the flow from windscreen to feet, etc. and then it only makes this sound and goes away, it's not continously there.
#15 | ||
What's involved in pulling the dash out enough to fix the tubes? Is it a big job?
#16 | ||
Formally Kia Chaser
Tools required - 4 long thin tools, or the proper ford tool to remove the radio, 1 average phillips head screw driver, 1 stubby phillips head screw driver.
The screws may be VERY tight, therefore rubbergrip screwdrivers may work better.
#17 | ||
Fantastic Plastic
Complete to/including step 3 , (this next bit only takes about 2 mins extra to do and will save you heaps of time trying to squeeze in behind the cfp ), also imo put the car in gear position #1 before starting, to give you a bit more room removing the radio and cfp - if you have an automatic.
4. Turn the 3 cfp dials/controls to about 8 o'clock (full cold & fan off - on the last 2 dials ) . 5. Remove the glovebox ( just clips out ) . 5. Behind the glovebox to the bottom left / unclip the multi-colour vacume hoses/line connector , follow the the coloured vacume lines from the connector you just unclipped to right behind where the bottom of the glovebox would be , the coloured hoses/lines are clipped onto the plastic here with small metal clips , get a flathead screwdriver and pry them off from the under side of where they are clipped on, or use long nose pliers and pull them off . 6. Unclip the thick controls cable from its plastic mount just behind where the glovebox would usually be ( there is only 1 thick cable there ) , unclip the cable retainer from the plastic mount. (leave the cable retainer clip attatched to the cable) . 7. To easilly remove the cfp without breaking it , Unclip the cfp pulling from the bottom first with hands on the bottom both sides , pulling evenlly working your way towards the top. 8. Once you have carefully unclipped the cfp about 2" to 3" away from the dash , behind the cfp unclip the clock connector/plug , unclip the aircon connector/plug and unplug the power connector ... untwist the bulb/globe connector for the ashtray and unclip the plug off the back of the cigarette lighter ( 4 electrical plugs to disconnect and 1 light bulb holder to untwist form the ashrtay mount in total on series 2 xr ). 9. The whole cfp is now ready to remove from the dash , carefully pull it towards you while guiding the vacume lines (the one you unplugged from behind the lower left of the glovebox ) and cable (the one you disconnected from behind the glovebox) . Pull the cfp fully away from the dash while carefully guiding both vacume lines and the cable ( still attatched to the cfp and controls ) through. When the cfp is removed you will have the vacume lines and the cable still hanging off/attatched to the cfp . Much easier to access the back of the cfp now ( can take it inside and work on it ) , you can make sure all hoses are propperlly clipped onto the controls, and change any cfp or clock lights while at it if needed. Installing again is just the same procedure in reverse . All up really , after the radio is removed , this whole procedure only takes about 5 minutes max to remove it / and about the same to put it back . Its actually quicker and easier than trying to squeeze a small stubby phillips head screwdriver behing the cfp to undo the clock and the vent , and at least you'll know for sure that 'ALL' the vacume lines are on propperly for sure , unlike when the cfp is still semi connected you can't see behind it , your just judging off feel . cheers .
------------------------------------------------------------ :eclipsee_ Last edited by XR6-VCT-2000; 23-06-2006 at 01:26 AM. |
#18 | ||
Formally Kia Chaser
IMO - just to check vaccum hoses, I don't believe you should have to actually remove the whole cfp... but yeah - the above should give you something to do on the weekend now - enjoy!
#19 | ||
Iam not confident doing things like this myself I'll get someone else who knows about this. Interesting I did as FALCONSR suggested, full blower moving b/n settings and hot/cold and now only one setting has the noise (go figure) and that is footwell, the one I want to work. I think I will continue doing what FALCONSR suggested as it may have been a blockage?
#20 | |||
Fantastic Plastic
Once you know how to remove the cfp, imo its actually quicker and easier to fully remove it rather than trying to squish a stubby phillipshead screwdriver though the small gaps to behind the cfp to undo the above . Besides that, once the cfp is removed there is no need to undo anything else to check the vac lines, and they can then be checked propperly. Definatelly sounds like a hose is not on propperly though ;) , i had exactelly the same noise as you Sednwol, a 'shhhhhhh' noise in just the footwell .
#21 | ||
Walking with God
There's been some good step by step instructions given here, they's go great with a photo tutorial as well.
Anyone keen to take apart the dash? LOL! I'm asking because, I don't work well with just a written set of instructions, I need the pics as well. A tutorial like this could help a lot of people out. Just a thought! GK
#22 | ||
Fantastic Plastic
I originally used Russells document in the Tech part first time i dis-assembled it , there is a few b/w pics there , no photo's though , maybe not to clear for someone not to sure whats what , helped me though .
http://www.fordforums.com.au/vbporta...warticle&id=37 I might post some photo's on this soon as it would only take me a few mins to remove the cfp and put it back in, for the sake of making it heaps easier for others who unsure. cheers
#23 | |||
Barra Turbo > V8
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
#24 | |||
![]() I sold the HQ in 92. So its been 14 years. Severely withdrawn. Like you said, theres some well price XR8. Like the one Whoosha is selling for his mate. Some bargins to be had. |
#25 | ||
_Oo===oO_
Let us know how you go if you do plan to start pulling things apart. Mine makes the same noise also, coming out of recycle. Been that way since new so I thought it was normal.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
#26 | ||
I've got a noise on my which sounds like the fan blades may be broken. My E-Series was famous for broken fan blades. I think the same has happened to the AU.
