18-03-2006, 11:35 PM | #361 | |||
Oops, I slipped....
Stockstandard (and others) simply asked a question, which still hasn't been answered, which automatically questions the reputation and results of this dyno run (or 15). The question being what reading did you get with the intake pipe attached to the TB, but with the airbox removed. If you expect people to believe the power figures put down in this thread, without any real proof, then I think you are mistaken. It's simple human nature to not believe things over the internet that are basically, unbelieveable. I (and others) really fail to understand how an airbox can have a 9rwkw restriction at approx 3500rpm, and then have a 10rwkw restriction at around 5500rpm. It makes no sense at all.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
18-03-2006, 11:36 PM | #362 | ||||
What kind of results do I need before we can talk further?
18-03-2006, 11:42 PM | #363 | ||
Built Ford Tough
One stage HELL HP cam please...
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
18-03-2006, 11:46 PM | #364 | |||
I'll put an end to this simply. Without actually being in front of the dyno and monitoring evey step of the process there is no way to convince you guys it happened. Thats fine, I dont feel a need to justify my decision to do that.
Instead I'll let G&D finish the mods that we are doing and I'll take it to the track. ET and MPH will be the final judge I think. Is that fair? Quote:
G&D have been around doing big things a lot longer than I have. I think starting a thread in a forum and having a few dozen people paticipate in it is hardly massive advertising on a global scale you make it out to be.
18-03-2006, 11:47 PM | #365 | ||
hi GnD just a question im sure u wont mind answering,(after the latest questioin of corse)
but do u have any times on cars that u guys have worked on that are simalar to mine or caspers..just to make some of us feel better...dont worry i wont say ur bragging bud : |
18-03-2006, 11:48 PM | #366 | ||
GT-P #0336
An impressive gain there Shane. Well done to G&D. Time to 'bin' the current mods and book mine in. PM headed Glenns way. I want my super special secret goodies too - and a sticker! :
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST ~Tuned By Bluepower Racing~ |
18-03-2006, 11:49 PM | #367 | |||
Chairman & Administrator
1. The requirement to filter incoming air into an engine is purely related to longevity of the engine - for example F1 engines run with almost no air filtration and as large a ram air box as the rules will allow them. 2. Anything that sits between free air flow and the actual intake manifold is going to provide some loss of available air flow to the engine. This effect is exacerbated in a dyno situation as even with fans the available air quanity is not the equivalent of (even the relatively ineffectual) standard ram air effect. 3. Typically factory air intake setups on most cars will be optimised to provide sufficient flow of air for the RPM range they are generally expected to operate in. 4. Any improvement to the air flow capabilities of the inlet manifold and/or head or operation at higher RPM than that factory operating ranges will result in insufficient air flow to meet the requirements of the engine with the potential to see further loss of horsepower as RPM increases. There are actually a lot of other factors as well but for the purpose of a simplified explanation this will suffice. Russ
Observatio Facta Rotae
18-03-2006, 11:59 PM | #368 | |||
I think the confusion lies when a significant restriction at 3500rpm seems to have no greater restriction at higher rpm when twice the amount of air is being drawn through.
19-03-2006, 12:02 AM | #369 | ||||
Oops, I slipped....
We are talking about a 120rwkw AU 6 cylinder on a dyno, not a 20,000rpm V10 3 Litre F1 car doing 300Km/h. An AU 6 cylinder and an EF or EL 6 cylinder engine have a lot more in common than a modern Formula One engine.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" Last edited by Aaron_EF8; 19-03-2006 at 12:03 AM. Reason: Added extra info |
19-03-2006, 12:06 AM | #370 | ||
that sound like french to me anyway,speak english please not everyone is an expert :
19-03-2006, 12:14 AM | #371 | |||
G&D Performance Australia
The development was performed on the car by us some time ago utilising a mild cam & cylinder head option tuned with unichip.We recently dyno'd it at 147rwkw's. We have a lot more R&D under our belt since then & once finished we'll get back to the track. |
19-03-2006, 12:16 AM | #372 | ||
In the end it really doesnt matter does it? My money, my car, my mod. If you dont believe it I can understand that and accept it. It is your right to (and questioning is good in the end). Still, the ET and MPH will tell the tale in the end wont it. I think a "shakedown run" soon enough will be in order to put it all to bed and, after all the other work we do on the car this week, I dont think the 10rwkw airbox will have much of a spot in the sun. Hell, I put it up as it was the least impressive result to date..
19-03-2006, 12:17 AM | #373 | |||
19-03-2006, 12:27 AM | #374 | |||
19-03-2006, 02:12 AM | #375 | ||
Hmm Project XW VAN !!!!
Wow 3 more pages in just one day...what alot to read :nutsycuck
Many things I want to say but I think it has all been covered to some degree. The G&D Cold Air Intakes work. Simple as that. I was there, I even helped fitting it ect. The car did not leave the dyno at any time and all the testing was done by exactly the same guiedlines. I belive a few of the main reasons it works so well is due to, The amont of air the box holds, the surface area the filter covers, it does not draw air over the hot radiator and the box is insulated to help with heat soak from the engine bay. I will take it for a drive if you like casper and spend some time doing extensive trye reserch if you like..... : :sm_headba :sm_headba :sm_headba Kev......
I'd rather be BLOWN than stroked Yella Terra Supercharged Power Output? ENOUGH TO BREAK EVERY THING MORE TIMES THAN I CARE TO COUNT POWERED BY VISA MASTERCARD AND MORE VISA (And now a mortgage extension) Disclaimer : : Anything that seems or sounds illegal is all in my head and due to an over active imagination... :
19-03-2006, 02:32 AM | #376 | ||
Two > One
well, I could post a few things, might reserve my judgement, but based on the contence of that dyno graph its not looking positive so far, not at all. (8.4%)
Box looks good. What MAP pressures were seen with the stock box and with the new box (kPa)? What MAP pressures (kPa) were seen with no box? on another note. I have a few fluid dynamics books here if people wish to borrow them!!
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - Last edited by Walkinshaw; 19-03-2006 at 02:38 AM. |
19-03-2006, 07:12 AM | #377 | |||
As for the airbox...... In the end it really doesnt matter to me if people agree, disagree or ar indifferent to if it works or not. This is because: a) My car b) My money c) My chioces d) The airbox setup is part of a much bigger picture e) It has has proven benifits on other cars f) The vast majority of those who want there 2cends worth of disagreement registered actually do not drive a car which would even fit this airbox, nor would they ever consider getting one if it did. So really what I see is this... People are disputing the readings on a mod they really haven’t seen in detail, on a car model they don’t have, running an engine they don’t have that has a reputation for unusual behavior to mods, from a dyno that has been used and accepted by some of the fastest cars on this forum and LS1, by a company that has be modifying performance cars since before most of us were born, who hold national records, who have made a long term business based on “no rubbish” results? This is based on a few years of amateur intake fiddling, some discussions with a few engineers and maybe a book or two? Sorry guys but I don’t mind if you don’t believe it and need to try and justify it to the forums, but don’t expect to be given a soapbox here. If it didn’t react as you expected to your cars then feel free to make your comments but its not your cars, its mine. Its not your money, its mine and its not your ET and MPH, its mine. Personally I am happy with the result and will be seeing the results on the track soon enough I hope. I guess its just lucky for you that its not available for E series cars.. so you don’t have to lose any sleep over it either. Understand that this thread is simply about a set of mods I'm doing to my car. Feel free to read and comment but if you start agrueing a point that has absolutely no relavence to you then dont you think its getting all a bit hard? I mean seriously, whats the point? : In the end just say its great or you dont agree... to be honest I'm just letting people know whats being done, I am not really interested is debating flow dynamics, filter properties or the price of fish food in France. I have got a set goal in mind, G&D are doing mods to reach that and when the car hits the track over the next 12 months we are going to reach that goal. Argueing over what is, by rights, a very minor mod like this is stupid in epic porportions. For all those who disagree with it.. what do you expect to gain? Respect? Ego? Me to rip it out of the car and drive my car off a cliff? Sorry, not going to happen
19-03-2006, 08:55 AM | #378 | ||
Not only did you gain more power but it looks awesome as well. G&D can you please open up shop in Brisbane :
Current Ride 2012 Mitsubishi Triton Dual Cab ute : |
19-03-2006, 09:01 AM | #379 | |||
If you give them a call Im sure they could arange to mail you a CAI and you could fit it your self....The real question is, Can they keep up to demand???
19-03-2006, 09:15 AM | #380 | ||
Fantastic Plastic
Don't worry about all the laa-dee-daa Casper, I for one will keep my critical comments to myself until i actually see it running after mods complete, sounds good so far though ;) . I have eaten my words plenty of times years ago due to jumping the gun too soon, from to even some of the smallest mods making a huge difference on 1 car , to on another car the same mod but not much difference at all. It's all good so far ;) , keep it coming, you got me hanging for more details .
..To people nit-picking -->Allthough we all have the same cars sorta here, they are still all "individual" cars/motors with their own good and bad points to them all, all which can help a mod actually work well - or not do much at all. So save the judgement until you see the final results. Again plenty of thanks to G&D Performance, Nice to see someone taking the time to work with the VCT engine as no-one else seems to of have. I allways thought the VCT had plenty more potential than what it can do , reason why i bought it !, and now just by chance you guys are starting to look into it .. WD .. keep up the good work, looking foward to hearing the final results on Caspers car, and also maybe any other kind of advancements/mods can be had with the VCT ... cheers ;)
19-03-2006, 10:48 AM | #381 | |||
Back on the road
Wouldn't it be a sequence of pulses/waves, changing in frequency as rpm rises? And surely pulsing air would have significantly different behaviour in an airbox/intake pipe environment than a steady stream of air...? And why is everyone so hung up on airflow? What about air temperature? Question for G&D. What is more significant when designing an airbox for the AU; the airflow or the air temperature? Where is the IAT sensor in the i6?
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
19-03-2006, 10:50 AM | #382 | ||||
I have raised concerns (which I dont think is a bad thing at all), and backed up everything I have said with the source of that info so everyone knows where i am coming from and has the opportunity to correct me if im wrong (and there is a good chance I am wrong), but all you guys seem to be doing is labeling me and others knockers. Do you want a forum where the only way members know how to modify cars is to write checks? Why not actually address those points im raising - Im not trying to label this product useless, just trying to understand how it is supposed to work. Just because people like myself dont have a business name doesnt make what we say wrong, or not worthy of a response and I find your attitude towards amateur builders very poor. Yes I am an amateur, but that doesnt mean that everything I do is not to a professional standard. My work certainly stands up well against the 'professionals' you were flying the flag for for so long! And why cant I discuss a product that has no relevance to me? Am I not allowed to post in V8 tech because I drive an I6? As much as you would like to separate yourselves from e-series, the fact remains that your engines are very similar to ours (especially seeing as how many of us have a number of AU parts in our cars), and if it apparently works so well for you guys then naturally we will be interested to see if it works on ours. Many of us e-series guys know people with AU's, so you would think if you treated us as potential customers we would spread the word for you. Guess not. It may be irrelevant to you in your grand scheme, but when you post about a 10rwkw restriction in a factory setup people are going to take notice. Re-read my posts - I have raised valid some points and given enough detail so that anyone has the opportunity to point out where my thinking is wrong.
19-03-2006, 10:52 AM | #383 | |||
Back on the road
Just dont forget to post up the RA from the day, so we can take the weather out of the equation as well.
19-03-2006, 10:54 AM | #384 | ||||
19-03-2006, 11:05 AM | #385 | |||
Back on the road
Are you the guy running the megasquirt? Have you had a chance to get track or dyno numbers from it yet?
19-03-2006, 11:14 AM | #386 | |||
Yeah im running an MS2, but unfortunately no track or dyno yet - Ive been overseas for a while and otherwise occupied with work commitments (slack i know : )
Comparing in box air temps to ambient, the biggest difference I can find in any datalog is 2 degrees, and that is at idle. As soon as the engine has some rpm, the temp is ambient or withing 1 degree, and the resolution of the sensor is 1 degree. Edit: Actually no i lie. Looking at datalogs from the middle of summer (damm hot days, 35-40 degrees) and the difference goes to 6-7 degrees at times. This is comparing the running measured temperatures to the initial temperature read on that day (so air temp with cold engine vs air temp with hot running engine). My datalogs are usually done over a short period of time so it should be a reasonable comparison.
19-03-2006, 12:59 PM | #387 | |||
TL40 Wagon?
19-03-2006, 01:10 PM | #388 | |||
TL40 Wagon?
19-03-2006, 01:14 PM | #389 | |||
Cuban... nothing like it
For the benefit of us all, wouldn't it be best to be detailed in another thread rather than lost in this one?
I know I would definitely be interested to read the personal experiences of what and what does not work. Aaron Ef, thanks for the great laugh, needed that this morning. : : : : : : :
19-03-2006, 01:16 PM | #390 | |||
Glenn |
