09-12-2006, 02:12 PM | #511 | |||
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
2023 Superb Sportline - Steel Grey 2024 RS 3 Sedan - Mythos Black 2024 Mustang GT - Vapour Blue (built 31-10-2024 - on "TIJUCA" ETA mid-Feb '25) |
09-12-2006, 05:35 PM | #512 | |||
Sundeep |
10-12-2006, 06:02 PM | #513 | ||
Does Steve have a car?
Weathers cooled down a bit so i thought i'd get stuck into the remaining items on the car.
Tried running the handbrake cable today, and to my amazement it's looking to be an incredibly easy job. I'm not finished tho as i need to have a look at an EF to see exactly how the cable runs under the car, but it looks like I should be able to use the existing brakets to hold it into place. Need to wait for my mum to come back so i can have a look at her EF. Basically if everything goes right and no more mods are involved, it'll mean that the EF handbrake setup should go relatively easily into EA-ED's without "too" much modification. I'll let yous know how i go (and write up a list of exactly what's needed ;))
AKA Mr Silver Chasing reliability....: "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
10-12-2006, 06:05 PM | #514 | ||
Good stuff Steve, an EF handbrake would be awesome compared to these other shitty things we have.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
10-12-2006, 07:29 PM | #515 | |||
Tuned @ Pitlane Frankston
The cable/handbrake itself is not the issue..
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
10-12-2006, 08:22 PM | #516 | ||
OK had a look at my mum's EF just now. There are two brackets that secure the cable underneath the car. The EA-ED's have one of these brackets which is identicle to the EF/EL one, but the other bracket either hasto be cutoff an EF wreck or something needs to be made up. Wont be difficult to make so i'll probably go with that option (it's just a tube shaped bracket that holds the handbrake cable into position). Other than that, i've hooked up the cable and it works perfectly Another item crossed off the list
For anyone wanting to convert to an EF/EL handbrake, you will need to do a few things. Firstly you may possibly need to install an AU centre console which will allow the handbrake to clear. I haven't done this but i couldnt imagine it being overly difficult. Secondly you will need to make a bracket on the floorpan so that you can fit the handbrake into position. Next a small hole needs to be cut into the floorpan to run the cable through. You will then need to install the EF/EL diff. This will require you to change to the EF/EL style brake calipers aswell. To fit the diff, you will need to get EF/EL bushes pressed into your trailing arms. Also you will need to remove the rear section of your origional brake lines and swap them over with EF/EL lines. This is not overly difficult as the fitting is in the correct position and there is already a mounting point to hold the brake line distribution block into place. You will then need to fit two L shaped brackets that will allow you to bolt the solid lines to the rubber section of the line that goes to each caliper. After that, you will need to make up the second bracket underneath the car that secures the cable, then it's simply a matter of hooking up the cable as you would on an EF/EL. Ok it's not that simple but nonetheless it's completely do-able
10-12-2006, 08:37 PM | #517 | ||
in other words just buy an EF/EL.
10-12-2006, 08:40 PM | #518 | |||
What's wrong, scared to get your hands dirty?
10-12-2006, 10:06 PM | #519 | ||
Parts bin special
Gee Steve, still not going! I was thinking you'd have it on the road by now :P
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
10-12-2006, 11:30 PM | #520 | |||
10-12-2006, 11:38 PM | #521 | ||
hmm.. one problem after another... sounds like my car
10-12-2006, 11:40 PM | #522 | |||
10-12-2006, 11:53 PM | #523 | |||
Parts bin special
Reminds me. I'll need to adjust mine, as I'm having trouble getting it to fully engage. I'll do that tomorrow
11-12-2006, 12:01 AM | #524 | ||
[EBGLT]
Minor clutch adjustment or maybe the clutch has seen better days
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
11-12-2006, 12:02 AM | #525 | |||
I did this, attached the clutch cable, and it was pretty much spot on. Never had an issue with it at all. I don't like EA flywheels and clutch assemblies at all..
11-12-2006, 12:10 AM | #526 | ||
Parts bin special
It'll just be a minor adjustment. It's got a heavy duty clutch that looks brand new. It just seemed to get worse today, so just need to give the bolt a couple of turns and it should be fine
11-12-2006, 12:23 AM | #527 | |||
I always thought the nuts on the cable were for pedal position and fine tuning only. If the cable and clutch are in good condition, it shouldn't need adjusting.
11-12-2006, 12:26 AM | #528 | |||
Parts bin special
Back on topic, Steve, good luck with your clutch. I still want to cruise with you
11-12-2006, 02:44 AM | #529 | ||
My cars got an EF/EL flywheel that was machined before installation. The clutch is also a brand new Xtreme cusion button clutch, and my clutch cable is brand spankers as well.
Problem is that when we adjust it to the point that we can get smooth gear changes, the cable on the clutch end is too loose and keeps popping off the fork. Anybody know what we are doing wrong?? This is the only thing that's stopping her maiden voyage :( Everything else is done (well everything that is a requirement for a quick spin round the block :P)
11-12-2006, 08:26 AM | #530 | ||
PM me if you want
Cable ties will fix it, its an EA stop avoiding the obvious solution ............ LOL
11-12-2006, 06:49 PM | #531 | ||
sounds like the cable is stuffed, or the clutch fork is bent or incorrectly installed.
11-12-2006, 06:53 PM | #532 | |||
Parts bin special
Off topic, but I sorted my clutch out today, just needed adjusting
11-12-2006, 06:57 PM | #533 | ||
Clutch fork is bent or incorrectly installed, as Damo said.
Or, it could be the little hook thingy at the end of the clutch fork that's buggered. Is that new?
11-12-2006, 08:02 PM | #534 | ||
11-12-2006, 08:08 PM | #535 | |||
lol good to see Wilson and Alex approve.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
11-12-2006, 08:11 PM | #536 | ||
windsor user
It Lives!!!
11-12-2006, 08:13 PM | #537 | ||
Parts bin special
Great to see Steve! LOL at John and Alex
11-12-2006, 08:13 PM | #538 | ||
Shoot.
So how's it go!!!!!
20V Turbo |
11-12-2006, 08:13 PM | #539 | ||
Look everybody! No tow rope :P
11-12-2006, 08:14 PM | #540 | ||
good stuff - now for some video of it moving please
