17-12-2006, 09:55 PM | #31 | ||
Riding The Lightning
EF_Machine has your new cam made any difference to the exhaust note of the car? just that at the moment I am lovin how my car is sounding and I really dont want it too change the note too much if I put a different cam in
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA |
17-12-2006, 10:58 PM | #32 | ||
Mine sounds better with the 1636 installed...
17-12-2006, 11:13 PM | #33 | ||||
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
18-12-2006, 06:10 AM | #34 | |||
What Wheelspin?
not really. put the cam in and it ran like a bucket of ****. went to the dalton dyno day to check my AFR's and it was pretty bad. i was fouling spark plugs, blowing more smoke than a deisel and would mis-fire all over the shop. we all thought it was the chip for sure. turned out my cam was in the complete wrong position : . it was at factory zero, and it needs to be advanced a fair bit. still managed 134 RWKW with it running like that and on a 35 deg day : . (those who were at the dyno day, will know how bad it was running. they needed oxygen masks! : )
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
18-12-2006, 07:26 PM | #35 | ||
so how does it go now Mr_4.0 ?
18-12-2006, 07:44 PM | #36 | |||||
Interceptin'
'95 EF II Falcon, 'INTERCEPTOR' '72 XA Fairmont Coupe, 'XA Muscle' |
19-12-2006, 12:00 AM | #37 | |||
19-12-2006, 06:41 PM | #38 | |||
Smash the Boost
Ford didnt build it. Its a BTR box Built To Rape Solenoids. The left the S out cos BTR93LE is better than BTRS93LE. Geddit?
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
19-12-2006, 07:59 PM | #39 | |||
What Wheelspin?
i'll start a thread bout it when i get it back. and hopefully have a dyno run done after chrissy.
19-12-2006, 08:00 PM | #40 | ||
What Wheelspin?
sorry, i only had 3 inches before dailing in the cam, i cant remeber what i have now....
20-12-2006, 12:33 AM | #41 | ||
Tuned @ Pitlane Frankston
Get a cooler EF Machine. Trust in me when I tell you this.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
20-12-2006, 12:37 AM | #42 | ||
Last warning
Yeah, listen to Yagz.
for the price of a transmission cooler, get one. bigger the better. i'd recommend one on a stock car.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
20-12-2006, 12:44 AM | #43 | ||
It's not so much that a cooler is needed because you give your car a hard time, it's needed to prolong your transmission life. ~$150 to fit a cooler, or ~$2000 for a reconditioned 4 speed.
Especially in the hot summer we're gunna have, you don't want your radiator cooling the transmission fluid. Transmission coolers should be standard on ALL ford 4 speeds. The problem was cost cutting. Unless you had a tow pack from factory, no cooler was fitted, because it wasn't deemed 'necessary'. You should see some of the cooked transmission we get in at the workshop. Nasty sight..
20-12-2006, 01:55 AM | #44 | |||
Gunna girlie-man
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
20-12-2006, 06:19 AM | #45 | |||
20-12-2006, 11:12 AM | #46 | ||
so would this cam run on a std computer? i'm looking at getting a either a regrind or a manual for the el. i think the manual would go ahead first, but just doing my homework on the cam. only thing done on my car is pacey extractors and a 2 1/4inch exhaust
20-12-2006, 07:10 PM | #47 | ||
Interceptin'
Where should i be looking for decent priced trans coolers?
And should it be genuine ford or are aftermarkets fine to use?
20-12-2006, 09:09 PM | #48 | ||
Aspiring mr efxr
Davis Craig are ment to be up there in coolers aren't they?
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
