Old 26-05-2008, 01:10 PM   #31
TOASTED
JMM modded EF
ok lets say this. is an auto that is fully worked (stally, shift kit etc,) going to be faster than a fully worked (not sure of the possible mods) manual?
Originally Posted by ILLaViTaR
Guess the alcohol tax is turning people to mind altering drugs.
I drive : A heavily modified EF Fairmont with a JMM dev5 cam, worked head, 3.5" mandrel bent intake, exhaust, and a few other bits n pieces like a stally etc.
"She goes like a zirtek"
WANT A FAST FORD RING THIS BLOKE V V
Abbott Engines for HeadWork
20 years experience
PH Rob on (07) 5526 3883
TOASTED is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2008, 07:39 PM   #32
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
yes it proberly will be faster, but more fun? dont thnk much can be done to the manuals, just strengthing i assume.
EF Hoon is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2008, 08:08 PM   #33
benny_mac
benny_mac's Avatar
hey benny mate the JMM stally stalls to about 2800RPM with my mods Jim reckons "RECKONS" it will stall to around 3100RPM with F.I
Yeah, since i got the tune thats about what mine stalls to.
The stally pretty much eliminates the crappy BTR takeoff, i gained a full car length off the line against my bro's car with the stally. Before the take off would be a little sluggish and i'd have to wiat till the cam gets goin before i pulled away, now i'm ahead of him from the word go. Best $381 dollars i spent.
New Project: 1980 MK2 Escort Panel Van, 2lt, auto
Soon to be painted running a 4.0ltr v6
See the build here
http://www.fordforums.com.au/showthread.php?t=11388068
You Have Freedom of Speech Just Choose to Remain Silent
benny_mac is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2008, 10:10 AM   #34
TOASTED
JMM modded EF
lol mine cost $700...... *#c K you JMM!!!!
20 years experience
Old 27-05-2008, 12:44 PM   #35
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Yes Auto Faster............
Here is the issue with a manual - ITS MANUAL
You have to MANUALLY stall it up, (you can get this wrong - burn the clutch)
You have to MANUALLY change the gears, (you can miss a gear)
You have to MANUALLY make sure you change the gears at the correct max power/max rpm - its MANUAL
If you want fun the put a manual valve body in your Auto so you have to change gears - benefit of this - NO CLUTCH - you will have the perfect stall everytime
There is no ifs and no buts, if your Auto is done right then the Auto will be faster.....
Funner is not FASTER and thats the question here i thought?
If you want to compare a Stock Auto with a Stock Manual then yeah maybe STOCK manual is faster as you can Manually Stall it up to the correct rpm, but add a High Stall to that stock Auto and you will then always see the stock Manual guys in your dust
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2008, 01:44 PM   #36
TOASTED
JMM modded EF
champion. exactly what needed to be said. instead of starting another thread, how do you make an auto stay in the gear you want it in? e.g. i manually select third but if i plant my foot it will jump back to second maybe even first.
20 years experience
Old 27-05-2008, 07:18 PM   #37
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
im still not convinced, maybe a auto with high stall and 4.11 diff gears would beat a manual, but not just high stall. he said he only gained a car length with the high stall, a stock manual would do better than that i would think, first gear in auto is way to long!
Old 27-05-2008, 07:26 PM   #38
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
what if u get it right, mad launch with little wheel spin, dont miss a gear, and a really a real driver should be able to tell when to shift... so all things been equal, which is faster?
Old 28-05-2008, 12:53 PM   #39
TOASTED
JMM modded EF
answer?
20 years experience
Old 28-05-2008, 12:54 PM   #40
TOASTED
JMM modded EF
good question
20 years experience
Old 28-05-2008, 01:18 PM   #41
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
answer?
mine used to do the same when it was auto, i asked a mechanic about it as sometimes when i tried to downshift it wouldnt work and when i wanted to hold first it wouldnt, it would change into second..same with holding gears, it would hold for a while then when i hammered it it would change down. from memory its a S5 soliniod? (spelling) that needs replacing at the top of the auto gearbox, he said it was a biggish job, so i got a manual instead.
Old 28-05-2008, 01:48 PM   #42
Sorted
Sorted's Avatar
A stock auto will always do this unless you modify it
If you want hard and fast shifts get a shift kit
If you want to use the Auto like a Manual then you have to fit a manual valve body... then you select the gears with your auto shifter.........BUT I DONT THINK YOU CAN DO THIS WITH A BTR 4 SPEED - you will have to ask an Auto Shop if they can
Old 28-05-2008, 06:03 PM   #43
benny_mac
benny_mac's Avatar
good question
Meh, what if....... What if your lane has a dry spot and more grip and the one next to you doesnt, What if the air going into you CAI is 5 degrees cooler that the air going to his, What if your sparkling autobarn sticker on the side of your car blinds the person next to you and he can't see what colour the light is.........
What if's can't be counted, like i said before auto's are fool proof, pretty much guaranteed perfect take off and gear changes everytime. Do you think a drag car would put a manual in his car based on a what if.....
But like you said if, just if the manual driver got every thing perfect and i mean everything, yes it would be prety close, but i'm still stickin to my guns saying the auto would be faster.
And a car length is a heap when your only going to the speed limit, just think from 0-60 and at 60 your already a car lenght in front of him.
See the build here
Old 28-05-2008, 08:33 PM   #44
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
very true, its a good gain considering the long first gear too, but the point i was making was just a high stall with standard auto would still be no match for a competent driver in a manual, buy the time u have hit 60 in auto the manual drivers in second pulling in the meat of the torque. high stall plus 3.7 or 4.11s are a different story...
Old 29-05-2008, 11:23 AM   #45
TOASTED
JMM modded EF
THANKS MATE
20 years experience
Old 29-05-2008, 11:34 AM   #46
big_waity
Windsor Man!
big_waity's Avatar
No-one has asked the obvious question!
Do you want it faster in a straight line or around a corner?
In my opinion, if you want to get low 1/4 mile times, go a worked auto, if you want to race on a track where you have to slow down for corners, go a manual.
I have done manual conversions on a few cars because I find they are much better, you can ease off the clutch if you wish, with an auto, you just smash it back a gear and hope for the best. Driving around town, autos are good for lazy people or people that can't drive, you know, people that miss gears and don't know when to change. But if you seriously want to get the power down hard and fast, go a manual. If you want to point it at the end of a drag strip and press the go button whent he light goes green then go an auto...
Wife's car - BA XT Wagon - Lowm shiney wheels, dark tint, no bottom half of front bar, faded paint :/
My Car - 93 Diesel Lux - not as fast but more reliable than her falcon!
big_waity is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2008, 01:00 PM   #47
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
exactly, well said! also worth noteing the manual box is soooo much lighter than the auto box its not funny, i could pick up the t5 by myself to move it around, but the with the auto 2 ppl struggled to move it, thought it might be worth a mention :P
Old 29-05-2008, 02:28 PM   #48
Dezza
Parts bin special
Dezza's Avatar
You're not wrong there! My old auto is still lying in my garage, about a year and a half after we ripped it out of my car! I just don't want to physically move it, it's that bad!
Old 29-05-2008, 04:03 PM   #49
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
it was so heavy, im thinking of lowering my car more cause its now higher! it was that noticable, and i have superlows with stockies lol
Old 30-05-2008, 10:30 AM   #50
vegabass
BASS ON BOARD!
vegabass's Avatar
All this talk about 1/4mile, fast or fun....just decide what your car is... a drag car?/cruiser or a street car. what ever you decide the right gearbox will be obvious. I did the conversion and it was worth it but it also presented many many problems. Id like to see some 60ft times of a stallie auto. Mine was 1.8 in a manual with standard 3:4:5 diff, no wheel spin.
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2008, 10:40 AM   #51
Sorted
Sorted's Avatar
Originally Posted by vegabass
......Id like to see some 60ft times of a stallie auto. Mine was 1.8 in a manual with standard 3:4:5 diff, no wheel spin........
If you had to do a comparison you would have to have the exact same mods as you car and the only difference being one has a manual and one has an auto.
The Turbo boys with e-series regret changing their cars to manual when they go down the 1/4 mile as its unpredictable every take off.
If you like Auto keep it and trick it up
If you like a manual change to a manual
Old 30-05-2008, 10:40 AM   #52
TOASTED
JMM modded EF
well i am 300km from the nearest legal strip. but in saying that i like to eat other cars at the lights. but, in saying that i like to take some corners nice and fast. gees i dont know what to do..........
20 years experience
Old 30-05-2008, 11:28 AM   #53
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
if u dont know what to do then keep it auto, saves alot of stuffing around, eg. to get the right manual at the right price, i had to drive 1000kms for it.. but worth it hell yes.
Old 30-05-2008, 07:16 PM   #54
big_waity
Windsor Man!
big_waity's Avatar
You must be a little smaller than me. You are spot on about it being heavy, but I move the autos around by myslef. Bench pressing one up into position is hard when you are taking it in or out when laying on your back. The manuals are a lot lighter.
Oh, another bonus of the manual, it is a LOT easier to get in and out if something breaks. Do your clutch and the manual comes out a lot easier, ok, so you won't have that problem in the auto, but still something to think about.
Old 30-05-2008, 07:22 PM   #55
big_waity
Windsor Man!
big_waity's Avatar
Spot on!
I personally prefer manuals, but there is nothing wrong at all with owning an auto. Own what is right for you based on what you need and what you want.
Old 31-05-2008, 10:01 AM   #56
TOASTED
JMM modded EF
lol ure not making this decision any easier mate :voldar02:
20 years experience
Old 31-05-2008, 06:34 PM   #57
EF Hoon
Sideways in my 33!
EF Hoon's Avatar
how much does the auto weigh? i might weigh mine tomorrow to see, the problem is the weigh and the awkwardness of trying to move it, but it would be a good boat anchor.
lol have u ever been in a manual falcon? maybe go for a drive in one...i know after i got mine in it blew away my expectations of how good it was going to be, such a huge improvment, in terms of responsivness and seat of the pants feeling of a faster car.
Old 31-05-2008, 06:44 PM   #58
HOEBAG
HOEBAG's Avatar
i like to eat while i drive
HOEBAG is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2008, 07:48 PM   #59
vegabass
BASS ON BOARD!
vegabass's Avatar
Not a comparison just interested to see if they were slow off the line but bullet proof during up high and gear changes or if its quick in all areas.
Old 01-06-2008, 01:49 AM   #60
big_waity
Windsor Man!
big_waity's Avatar
I prefer to eat in the time I save by getting there more quickly with a manual :P
