19-09-2008, 01:48 AM | #31 | ||
From what i have heard you say it sounds like it is the converter. And they do, do it. I have seen it before.
The auto cant cause your problem and neither can anything else other than no power to make it stall or stuck stator clutch. I throw this out there, but highly doubt it, if you are driving with traction control on, then it could be possible that something is wrong and it could be causing engine cut and reducing power to compensate. But if this was the case then turn it off and prob would be gone. Another question is once you up and up in the rev's and moving how does the power feel? Does it feel like it has lost it all round or just down low on take off. At 100kph when the lock up clutch kicks in what are your before and after rev's? Basically either its stuffed or something is up and your motor is just not producing any power at all in the low rev's in order to get it to stall, and for it to be that bad, it would have to be down like 80%+.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
19-09-2008, 10:26 AM | #32 | ||
MADED.6
once it gets to about 2000rpm it just takes off and feels great just off the line (im guessing thats because the cams power range is 2200-6500rpm).
the lock up makes the revs go from about 2500ish to 2100rpm at 100kph thats because i have 3.9's. i will pull it out and get the stally repaired as i am selling it all and going manual as i am a big lover of manuals. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
20-09-2008, 08:53 AM | #33 | |||
Back to Le Frenchy
http://cgi.ebay.com.au/ws/eBayISAPI....:X:RTQ:AU:1123
Here's a 2800rpm stall to suit an AU V8, they'll do it for $395 or deduct $95 if you do it change over.
20-09-2008, 10:33 AM | #34 | ||
hmmm they sound good, but are they?
20-09-2008, 04:12 PM | #35 | ||
MADED.6
i can get mine rebuilt for $150 so ill just do that thanks anyway russell.
cheers josh.
28-09-2008, 05:34 PM | #36 | |||
Rob
sorry to hijack thread. |
28-09-2008, 06:27 PM | #37 | ||
MADED.6
not a problem mate but mine doesnt make any noise just doesnt move and doesnt rev.
cheers josh
28-09-2008, 10:13 PM | #38 | |||
Rob
given my tyres are nearly slicks it used to just light up if i tapped the throttle. i'm just assuming its the converter causing the lag. |
