01-06-2009, 07:39 PM | #31 | |||
Force Fed Fords
The thing is, the dealers have to be strict as they may assume a ford will warrant something, only to be knocked back such as in this case (the F6). If that's the case, they then have to try and ellicit the money out of the owner, or offer some kind of sweetener to get the money out of the owner ie massive discount.
That's why some of the dealers are a little abrupt. This is not the first time this has happened at Dale, there is a G6E-T in ego that has been capa tuned numerous times and has been voided as well.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
01-06-2009, 07:41 PM | #32 | ||
exactly why i will wait to undergo ANY modifications for now
01-06-2009, 07:43 PM | #33 | |||
01-06-2009, 07:55 PM | #34 | ||
hi guys...i own a fg and most of them have had factory oil leaks around the timing cover..mine went back ford,they pulled out the bolts and shortened them and whacked them back in..oil leak fixed....It looked at first that it may be coming from the sump....If he could prove that it's a common problem or a factory stuff up...you never know....Have heard of some leaking oil from the head gasket...A little hard done by in my eyes for oil leaks.....If he blew the head gasket different story...well that's my 2 cents worth.....
01-06-2009, 07:56 PM | #35 | |||
335 S/C GT: The new KING of Australian made performance cars.. |
01-06-2009, 07:57 PM | #36 | |||
That would be like Ford saying, please feel free to mod your cars and track them! I am sure he knew the risk when he was playing with teh car |
01-06-2009, 08:01 PM | #37 | ||
Falcon RTV - FG G6ET
Flashed 36 times........ 360rwkw.
Sounds like another case of money getting into the wrong hands.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
01-06-2009, 08:01 PM | #38 | ||
mate every early fg turbo had oil leaks from the timing cover...factory fault bet they didn't tell him that....Draw the line don't know...but an engine flash isn't going to pressure the oil system......Fraud would say anything not to fix it....
01-06-2009, 08:08 PM | #39 | ||
alot of people push the envelope and know the consequences ........
360rwkw would def put more strain on most components of the engine/driveline i am sure the owner of the F6 knew the repercussions |
01-06-2009, 08:12 PM | #40 | ||
it's an oil leak... not a problem that has occured from high power outputs. sure over temp twice could have hardened seals, but I think it's a bit excessive.
2009 FG turbo ute 1983 Toyota sprinter- quick/fun car with a Nissan heart 2010 CRF250- when I want to get dirty |
01-06-2009, 08:13 PM | #41 | ||
Right out sideways
IMO ..... they (insert car company) warrant a product in the condition it leaves their factory. Once you start editing the PCM , bolt ons etc .... as already said you pay for it if it breaks
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
01-06-2009, 08:16 PM | #42 | ||
mate i'm with you....but if he can prove the oil leaks are a factory fault which i think they are..it shouldn't matter what mods are done....I can understand if he blew the engine up...broke a gearbox or clutch ford should wipe their hands of him...A little tough in my eyes when almost every fg has had factory oil leaks...
01-06-2009, 08:16 PM | #43 | ||
Flairs - Truckers Delight
i agree with ford. i would have told them to get lost too, under those conditions.
just like my mechanic is currently getting a nissan tiida engine reco'd, only 2yrs old with 40,000ks on the clock, it died. why not warranty? it had never been serviced, in 40,000ks.
01-06-2009, 08:19 PM | #44 | |||
01-06-2009, 08:21 PM | #45 | ||
If he can spend $$ on flashing it 36 times, surely he can spend $20 for a scan tool off ebay?? Delete the logs and such?
01-06-2009, 08:22 PM | #46 | ||
guys the timing cover bolts fitted to these cars bottom out in the block before there tight...
01-06-2009, 08:28 PM | #47 | ||
this is funny,we are all waiting on this thread for hell to break loose just like the one that got closed lastnight. ,well i am
01-06-2009, 08:35 PM | #48 | |||
Don't start me on dale......mate they couldn't find a root in a brothel |
01-06-2009, 08:39 PM | #49 | |||
You dig, we stick!
This bloke is silly imo.
They no longer have launch control on the GT-R as too many peeved customer's kicked up a stink about having to pay that much to replace the not-so-cheap gearbox. Even "Hitler" threatened to buy Porsche after his ordeal.
"....You don't put the car through engineering" - Rod Barrett. |
01-06-2009, 08:53 PM | #50 | ||
Put yourself in the same situation. How would you feel if your gearbox packed in 8000kms after warranty runs out. This car had done no serious off road was not fitted witha towbar blah blah blah. When is the last time you had a manual gearbox die? What breally peed me off was they said it would be assesed under there "lets be nice to customer program" or whatever they call it. Once it was apart they told me no warranty. I couln't very well go and pick up the pieces and get it erepaired so unfortunately I had to pay ford repair rates. Anyway thats my whinge i still own three fords but at least these are Aussie made ones. By the way the other guy this thread is about is a tool. You do these mods you have to accept the risks.
Cheers Steve |
01-06-2009, 10:00 PM | #51 | |||
Trev
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
01-06-2009, 10:09 PM | #52 | |||
7,753
Not only Ford either. Its not completely cut and dry and in my experience it is termed exactly as "goodwill"
BREAKING NEWS: The Pity Train has just derailed at the intersection of "Suck It Up & Move On" after it crashed into "We All Have Problems" before coming to a complete stop at "Get the Hell Over It." Reporting LIVE from Quitchur Bitchin' |
01-06-2009, 10:10 PM | #53 | |||
Regular Schmuck
I just don't understand why the vehicle should be warranted outside of its warranty period. I'd expect to have to foot the bill on a vehicle older than 3 years or has done more than 100k/kms. |
01-06-2009, 10:15 PM | #54 | ||
Silly boy. If it were me I'd have been a bit smarter about it and bought a spare PCM for around $600, flashed the bejesus out of it and kept the factory one at 1-2 flash counts.
2021 BMW M550i in Black Sapphire Metallic.
11.52 @ 120mph stock |
01-06-2009, 10:18 PM | #55 | |||
Ich bin ein auslander
Growing old is compulsory, growing up is optional! |
01-06-2009, 10:19 PM | #56 | |||
No Boundries
No SCAN tool can delete how many times a PCM has been flashed any engine component claim on a turbo now results in the PCM getting a quick trip to Melbourne for assesment before any warrenty work is carried out. Good on Ford to, nothing $#its me more than blokes who have all the cash in the world to get the thing putting 400RWK to the road and then have a big sook about warrenty whey the are asked to pay for something that broke because of this. : Running more boost can caues oil leaks as there is more pressure in the crank case I have seen a supercharged 5 liter that used to blow the dipstick out so yeah more boost can caues oil leaks.
FG XR6T Nitro, 6 Speed ZF, Tech & Safety Packs, Leather & Premium Sound. |
02-06-2009, 12:35 AM | #57 | |||
Lucifer's Angel
I developed a clunk in the back of the car, and though it was well out of warranty they pulled the back axle out, checked the diff over (found nothing wrong), tightened everything up and put it back in and didn't charge me a cent. Never heard the clunking noise again either.
SINISTER BA XR6 Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford... It's being beaten by a girl driving a Ford |
02-06-2009, 01:48 AM | #58 | ||
Years ago I had an auto tranny solenoid fail on el at about 108,000.
Was told it woud cost over a grand to fix. Had a whinge, as i had been complaining of shift problems for a few months before that at previous service. They fixed for free. |
02-06-2009, 08:17 AM | #59 | |||
Trev
02-06-2009, 08:59 AM | #60 | ||||
Force Fed Fords
