#31 | ||
Great choice!
I too had a 3v in a BA xt. Loved it and never had a problem. Torque on tap down low but it's completely out of breath at 5000. They originally went into the F-150 so they are most definitely a truck motor but purrrfect for a cat. Well done mate, I reckon you've just built the best jag conversion in the land.
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. Last edited by Mercury Bullet; 04-04-2017 at 03:07 PM. |
#32 | |||
Sent from my HTC_0PJA10 using Tapatalk |
#33 | ||
Good luck on the project mate, I too had haters when I said I was going to put a 5.4 DOHC boss into my cortina. It goes like stink.
As for parts hit the net and look in the states, plenty of parts from spark plugs to after market plug and play ecus. There are also plenty of performance camshafts available for the SOHC's over there to.
FGX XR8 auto 402rwkw- The new daily NC Fairlane 5.0 STD TC Cortina 5.4 Quad cam Boss 260 XD Fairmont 5.8 XB GS Coupe, no engine, future project VG Transit, AU 5.0 TC Cortina ute, finish 1 day I need to find a hobby ![]() |
#34 | |||
#35 | ||
N/A all the way
Love this for a swap, actually better for this sort of car than the quad cam. Would keep away from the t5, the tr 3650 is mor suitable as far as 5 speeds
BA GT 5.88 litres of Modular Boss Powered Muscle 300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight |
2 users like this post: |
#36 | ||
Oh ok, I will have a look, any ideas on what they came in, I'm not really on it as far as modern Ford stuff.
#37 | ||
Hi again guys, I got my new sump with pan at rear off a crown Vic. Dipstick on crown Vic goes through block not into sump itself. There is a plug in it though. Does anyone know if it's a snap bolt? I assume it is and will drill and easy out if I get no other option. Also, the plastic sensor that plugs into the side, is that really necessary? Is it just for level warning?. Any clues appreciated. Dean
#38 | |||
The dipstick hole im not so sure but I will be finding out in a couple of months when I too will have to place a crown vic sump onto a 5.4 but a DOHC. The early engines were just a ball bearing pressed into the hole.
#39 | |||
#40 | ||
Well there you go, found plug to be alloy tapered affair...with sump off, rolled engine on side and with air chisel lightly hit it till it fell out, put stock tube in for now, might be able to bend it a bit to suit, won't know till exhaust etc....
#41 | |||
I am Batman
I also like to do things differently and am not a purist at all. Rip out the asthmatic N/A 2jz and drop in what I have.
Rebuilt Boss260 with #Kellogs 1500hp forged and balanced crank#Manley forged flattop pistons with a 9.5/1cr#4340 forged h-beam rods with arp bolts#Clevit performance rod and main bearings#full ARP headstud kit#total seal rings#Mantic twin plate development clutch and lightened flywheel#Mellings uprated oil pump#Mainforce Performance Supercharger kit#AU motorsport 345mm big brake kit. Now sat on an engine stand going nowhere
#42 | |||
I will have to look at the 4v going into this ftruck to see if the block has the dipstick bung for the rear mount sump. If not I'll cut the dipstick section from the front sump and weld it into the rear sump.
#43 | ||
![]() Join Date: Dec 2006
3V is great engine. Minor issues aside.
I still wonder if it's actually going to fit into the engine bay. Jag engines bays are long but narrow. Not trying to be hater, just interested, I hope you can make it work. If all else fails, there is always the Barra Turbo option. I think that's already been done. It won't sound as good as a 5.4, but it would certainly be fun.
Oooh baby living in Miami....
#44 | ||
Hi man, it will fit, no bonnet mods either, I have a crown Vic rear sump on it now, and gearbox on the way...once here I can make mounts...so 99% in. Will post updates, intake may or may not fit as height may be able to go down another inch or so, apparently an extra inch is always good......sorry.
![]() Sent from my HTC_0PJA10 using Tapatalk |
5 users like this post: |
#45 | |||
#46 | ||
Hey guys, I have a problem. I bought a tremec t5 box from BA XR8. Issue is that starter motor sticks to side of bell housing. It's really wide with solenoid sticking out. Is there an option of a smaller unit or a starter with solenoid on top 90° to where it is now? It looks like it will hit chassis rail by an inch or so...any ideas appreciated.
#47 | ||
An idea of what I'm on about...
#48 | ||
Gen Y Falcon nut
This thread has me very interested... I did not think a modular would fit into a jag, i have a boss 260 sitting around and a daimler double six with no engine in it. Great job!!
BA XR8, Boss 315, T56, Herrod Cams, BPR CAI, X-Force head to tail, |
#49 | |||
I ended up getting a C4 conversion bellhousing from the states, it uses a mustang starter on the driver side now. It points towards the front like a early windsor or clevo. I've never seen an alternative one for these, mind you I never looked either. If I find something that may work for you Ill sing out mate.
#50 | ||
As you'd know, the Boss plenum will stand higher than the bonnet.
FG Falcon Ute Daily: E-Gas 4.0 I6, 3 seat 1 tonner, 2300kg Tow Pack, Carryboy, XR6 rims. 6 Stacker, Sat Nav, Reversing Camera, Sunnie Holder, XR dash & St Wheel - thanks Mr FPV! Jaguar XJ-S: Eaton S/C, I/Cooler, Haltech, DB7 rims, 1:15 Wakefield. Jaguar XJ6 Wife's daily :2006 Quartz Metallic, FORD Duratec 3.0 V6, ZF 6sp Previous relationships: FG GT, FG XR8 (+BA XT 5.4, BA AU, EF, EB, EA, EA & XF work cars) Jags XJ12 & XJ6, BMW E39 Wagon, BMW F11 M-Sport wagon, 20 of GMH FC-HQ |
#51 | |||
#52 | ||
Former BTIKD
![]() Join Date: Mar 2005
One of my old XJ12's was converted to a manual.
However this was using the original V12 along with a Dellows bellhousing and Supra 5spd box.
#53 | |||
#54 | ||
Well, I put box behind engine and sat it in place, fits almost too good. Need to make a bracket to move stick a few inches forward easy ish , starter at its widest point sits just above chassis rail so hammer time into passenger foot well. Just need a bigger hole in tunnel to allow shifter to come up an inch of so. And you won't believe the stock Ford gearbox bracket looks like it will fit perfectly...custom exhaust manifold will be a must , need pipes to drop in middle like Chev rams horns....
![]() ![]() Sent from my HTC_0PJA10 using Tapatalk |
4 users like this post: |
#56 | ||
Former BTIKD
The sight of that wiring brings back memories ......................not necessarily good ones
3 users like this post: |
#57 | ||
Oh yeah, that's another story, mostly ok now, replaced most as was butchered with scotch locks everywhere prior...
#58 | |||
Former BTIKD
6 users like this post: |
#59 | ||
Well, weeks go by, can't do much as injured but got ****s with bodgey selector mod so made a better one, even fits under console and through original hole where auto selector went. Next to cut tunnel to fit starter motor ...it's gonna be a drama...engine mounts arrived. The engine side, gotta fabricate the bottoms off cross member. Got pics if anyone interested. Will keep posting as I go anyway.
7 users like this post: |
#60 | ||
Any updates Dean?
