#31 | ||
Hello,
It matters not what you drive,just hope you don't turn into a vegetable if you have an accident. I drive on Gt Eastern Hwy,once a fortnight,just 200k's,and there are an equal amount of idiot car drivers and truckies and I don't want to get hit by either,but the OP was very lucky,so was the truckie! Every time I drive past an accident scene between a bike and car I am of the opinion the bike rider died! And,if I see a car crushed by a truck,even a 4 tonner never mind a triple full of ore then I assume the car driver is dead, its just an assumption,sometimes I think if they lived would they be better off dead! Sometimes I think "don't drive" if it scares you being on a congested road,or open road with big trucks if you are a nervy sort of person. People cause accidents,not the vehicles they drive! Cheers Billy. |
#32 | |||
Many others of you state it doesn't matter what you drive if a truck is involved. Traditional steel has strength usually 300 to 500 MPa, while high strength steel these days has strength around 1400 MPa or more. That's almost 3 times stronger if the thickness were the same, plus bonding techniques are used all along the panel seams, not only spot welding that easily split apart. Here are some articles: http://www.autofocus.ca/how-to/knowl...strength-steel https://www.hyundai.com.au/cars/smal...strength-steel http://msdssearch.dow.com/PublishedL...romPage=GetDoc You can see how Hyundai admits or advertises how an i30 has 'a significant increase in static rigidity over outgoing model'. Even if the crash was with a truck, there are reasons to believe it would have looked differently if it had been in a newer or more prestige car. I have done some panel work on FG and on BA/BF and seen how Ford has increased use of AHSS. Similarly from reading the body repair manuals for the new Ranger it is described that it has a lot more AHSS than previous PJ/PK model. Also from working on my BMW E90 and E83 I have seen how BMW for more than 15 years have been using high strength bonding of most of the body seams in the passenger compartment of their models. Ford Australia didn't use bonding, and many other non-prestige manufacturers doesn't either. Cheers,
'11 FG Turbo '08 Territory SY RWD And some non-fords: E90 M3 build, '07 Rocket III, |
