Old 30-12-2006, 03:24 PM   #31
Rollin
Rollin's Avatar
Damn you sorted it before I got to guess!
You will have to take some pics to show what you mean about the 'third clip' as I have no idea what you are on about.
I recommend you get a new cable and insulator (the bit with the hook on it down at the gearbox end) anyway, and fit them at the same time as you fit the new cleavis clip, because sure as eggs they are going to fail on you.
$10 says your clutch will feel half as heavy if you get a new cable and adjust it properly
It also pays to ring round for cable prices if you can...
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 03:35 PM   #32
DEVL-XR
EBII XR6
DEVL-XR's Avatar
haha yeah thanks for everyones input in this thread, i love the forums! its great to be able to jump on here and ask a few questions and come out wiser than before! at the moment i cant afford anything! christmas and modding my car has sent me broke! but i will get a new cable asap! the insulator seems to be ok but i guess its worth getting a new one too. the thrid clip i'm talking about can be seen in this pic:
its the square looking thing with a hole through it, it fell out somewhere but i have no idea where to put it back in!!
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 03:37 PM   #33
John_LS1
that square clip is off your brake pedal shaft im pretty sure...
Old 30-12-2006, 04:43 PM   #34
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
No john, it goes on the end of the clutch pin. There is also one for the brake, which is the same.
The split pin thing goes on last i think, after the black clip. The black clip is there for the clutch pedal bushes, which the cplit pin goes on after that, to hold it in place?
Ah, i cbf going under my dash to check, it's too hot.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 04:54 PM   #35
Christiaan
Christiaan's Avatar
Yeah, the black clip with the hole in the middle goes at the end of the clutch pin, and the small sirclip goes onto the clutch pedal to hold the cable holder (the broken thing in your pic) onto the clutch pedal. I think you should have 2 x clear plastic bushes, and 1x or 2x yellow bushes for the clip holder thing.
Old 30-12-2006, 07:36 PM   #36
needaXYGT
AU II XR8
needaXYGT's Avatar
I discovered that mine was starting to fray about 1 week ago. went to bursons and got one for $55. $70+ means you got ripped
i couldnt be bothered changing it my self so i took it into the ford dealer which isnt to bad here in Mildura, and had it done in 20 mins lol.
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2006, 11:57 AM   #37
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Yeah i didnt get ripped because i didnt get a new cable! bugger paying that much! thanks for the help shuresm58. i havent put the black clip on yet, i'll do it later. the clutch is working fine again tho. the only thing that isnt in that pic is 1x yellow bush. theres no clear ones. as i said i tried fitting 2x yellow bushes but it wouldnt fit onto the rod.
DEVLXR
