Old 18-03-2007, 02:04 PM   #31
XR6_661
Cane Farmer
XR6_661's Avatar
I'll wait till the novelty of having shiny parts under my bonnet wears off then I'll probably do something like that.
XR6_661 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 02:43 PM   #32
Cameronhayward
STR8 6
Cameronhayward's Avatar
JUZXR8 did you have to modify the airbox to make the pod fit?
Cameronhayward is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 03:04 PM   #33
JUZXR8
Hmmmmm
JUZXR8's Avatar
the only thing i did was put a small piece of pvc pipe, bout 4 inches worth, through the opening into the top of the airbox and sealed it with some silicon, then u just join your pod onto the pipe inside the box, it all fits in snuggly!
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 03:14 PM   #34
JC
JC's Avatar
Originally Posted by EAadam
Unboxed pods are illegal as they suck hot air into motor which in my theory throws all factory emission output levels out of whack. Dont quote me on that though, thats just my theory. But im 100% that unboxed pods are ILLEGAL. Besides if you are using the pod for more power, its useless if its sucking in hot air. We all know motors perform better with cold dense air.
That'[s the worst theory I've ever heard. Firstly, you state it's illegal because...and then the because turns out to be your opinion. Just because it's your opinion, doesn't make something illegal. What does make something illegal is that it is against the law.
Secondly, all EB onwards 4.0 I6 falcons have an intake temperature sensor, which measures the temp of the air being drawn into the intake, and adjusts mixtures accordingly, thereby keeping emmissions nice and safe (and legal).
Thirdly, where are unboxed pods illegal. Different states have different registration requirements, so to say something is illegal, you need to state what state you are talking about. It would also help to link to the relevant legislation/rules/guidelines to show that you know what you are talking about. For instance, in the ACT, an exposed Pod is totally legal, as long as the pod is secured to the car. Most pods come with some sort of strap to assist in doing this, therefore, these pods are legal in the ACT. Can't find the rego rules to support this, so let's just say I made it up - but without those rules, how would you know if I'm right or wrong?
Here's the NSW RTA possible reason why you may get defected for a Pod Filter:
Noise from filters and valves
Avoid fitting your vehicle with a pod-type air filter. This filter increases engine induction noise and may also increase exhaust gas pollution. Under clause 20 of the Regulation, it is an offence to modify an engine's air intake when it results in an engine noise level exceeding the maximum level specified in the Regulation.
Do not fit blow-off valves that vent directly into the atmosphere. Blow-off valves that vent back into the induction system are allowed.
Waste gate valves are nonstandard pressure release valves for turbochargers. These devices increase the noise from engines and can cause disturbance. If you are fitting these valves, ensure they do not vent directly into the atmosphere but into the exhaust system upstream of any mufflers.
So, the Pod is only illegal if the car's noise exceeds limits - pretty hard to do with just a POD. This is an EPA requirement, BTW, not an RTA/ADR requirement. http://www.environment.nsw.gov.au/no...hiclenoise.htm
Back on topic - that setup looks good, but what does the ribbed blue stuff do?
Ford Performance Club ACT
Old 18-03-2007, 03:20 PM   #35
yahoo189
yahoo189's Avatar
Iam just about to get a K&N pod filter, however i was thinking about just getting a pad and putting it in the box. With the POD filter, if ur EA-ED falcon doesnt have abs, you can bore a hole straight down underneath the old airbox. Of cource this isn't great but you get a lot of cool air coming through.
yahoo189 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 03:45 PM   #36
JC
JC's Avatar
Under ADRs, Pod filters are OK for EFI cars, except if they are oiled filter elements (interesting stuff - makes most K&N filters illegal):
TECHNICAL GUIDELINES FOR AIR AND NOISE EMISSION
REQUIREMENTS FOR MODIFIED IN-SERVICE VEHICLES
Information Bulletin
5
(a) Open element or pod type air cleaners on
carburetted vehicles are not permitted.
(b) Dry element pod type air cleaners are
permitted on EFI vehicles. Oiled, oil-soaked or
fluid-treated elements are not permitted. Any
sensors integral to the original system must
be retrofitted to the same approximate
location.
Source: http://64.233.167.104/search?q=cache...4FILE/1031.pdf
Old 18-03-2007, 03:56 PM   #37
XR6_661
Cane Farmer
XR6_661's Avatar
It was orginally going to replace the factory black ribbed stuff, which was all good in theory, but it was 3in" OD and so is the factory stuff, and the largest silicon joiners I could find were 3in" OD, which means it wouldn't fit without a lot of stuffing around. So I went and got a 90 bend to join to the straight section...Came up way short of where it should have been, at about the same point as the top securing section for the airbox. So I placed the ribbed section in the middle and adjusted it all to fit.
Old 18-03-2007, 04:45 PM   #38
jjj
jjj's Avatar
this is the best intake mod you can do, put an 80mm bellmouth inside the airbox lid. I have tried every pod setup, snorkel etc, and this setup works the best by far.
jjj is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 05:16 PM   #39
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Thanks for the clarification JC.
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 06:35 PM   #40
Gohan
JJJ i was gonna do that to my Airbox lid but my pod is kinda Big and tryin to fit 2 3 inch pipes in2 1 wont go unless i do some mods to 1 of the pipes. my pod came with a Strap and fits nicely on the Factory EF twin snorkle i'll post some pics of my set up
Gohan is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2007, 04:13 PM   #41
GT290
GT290's Avatar
Originally Posted by bentles
its so dumb how can changing to no air box cause the epa to get shitty? whats it do? suck in endangered wildlife or something?
if anyone knows the exact reason feel free to post it in here for me cos i dont get why pods are illegal unless boxed
I hve not read through all the posts so hope this is not repaeted but I think you will find epa will see it as a noise probelm. Induction om my car is very loud and it is in a box but out of the box even louder. I think there would also be other safety issues as mention here previously such as fire I supose.
But getting cought in the first place means you have some how attracted the attention so it self explains its self really.
Blue Power Enhanced
GT290 is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2007, 06:40 PM   #42
bentles
bentles's Avatar
nah its been explained pretty well on here, i havent changed to a pod yet and im not sure if i even will. im still yet to get pulled over once and its approaching 11 months and 10,000kms on my ps in a black lowered car with rims.... doesnt add up i know, but heh im lucky i guess
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2007, 06:53 PM   #43
GT290
GT290's Avatar
yeah no worries, I would be just considering the performance advantage or disadvantage with having the pod out in the open sucking hot air from around the engine bay any way. Aways best to have it direct from the out side I would think. Cheers
Blue Power Enhanced
Old 15-04-2007, 07:26 PM   #44
bentles
bentles's Avatar
yeh my mums got a pod in her car and i honestly cant hear it (yes its K&N) and its definatly sucking cold air only as its custom piped to a opening behind the front foglights. im happy with jamex panel filter in standard airbox with XH snorkel for the time being as i dont want to get defected or fined for something i can only just afford to add anyway.
Old 15-04-2007, 07:58 PM   #45
benny_mac
benny_mac's Avatar
i'm pretty (98%) sure pod filters are legal in S.A as long they are securely mounted and they are not oil filled.
New Project: 1980 MK2 Escort Panel Van, 2lt, auto
Soon to be painted running a 4.0ltr v6
See the build here
http://www.fordforums.com.au/showthread.php?t=11388068
You Have Freedom of Speech Just Choose to Remain Silent
benny_mac is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2007, 05:42 PM   #46
efgiar
rofl copter
efgiar's Avatar
JC.... please tell me were the IAT sensor is on a 4lt falcon? the only thing that i can think of that MIGHT be that is on the BBM's on the inside of the top plenum but i doubt it still.
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2007, 07:51 PM   #47
335JET
@jas_23_
335JET's Avatar
whats a iat sensor
335JET is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2007, 07:53 PM   #48
bentles
bentles's Avatar
Originally Posted by BOSS 4LTR
whats a iat sensor
intake air temp sensor
Old 16-04-2007, 08:02 PM   #49
335JET
@jas_23_
335JET's Avatar
thanks for that, i just had a look at the gregorys repair manual and found it.
to answer your Qu's EFGiar the iat sensor is located just below the throttle body and below the tps sensor and next to the fuel rail.
Old 16-04-2007, 08:30 PM   #50
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
wft everones airfilter connects to a pipe that leads to the top of the engine. mine goes out the bottom of the airbox then into what i think is the throttle body which is on the passenger side of the engine.- dw found the answer.
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread
2008 FG XR8 SEDAN 300RWKW N/A
2008 FG XR6 TURBO-UTE>>> SOLD
2002 AU3 XLS UTE>>>SOLD
Sick EB is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2007, 08:54 PM   #51
335JET
@jas_23_
335JET's Avatar
thats cause EA-ED throttle body is in a different spot to the EF/EL.
