View Poll Results: Engine bay colour
Black 34 36.56%
Same colour as the car 59 63.44%
Voters: 93. You may not vote on this poll
Old 17-04-2007, 01:20 PM   #31
AU dude
Flying high...
AU dude's Avatar
I thought it might be a good idea to continue this thread with everyone showing a pic of their AU engine bay, as there is a thread go on in the B series.com.au showing B series engine bays.
I'll go first.
Not the best, but better than stock.
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2007, 01:48 PM   #32
b2tf
not here much anymore
b2tf's Avatar
2024 F150 XLT
Old 18-04-2007, 09:01 AM   #33
james22
With da Warlords
james22's Avatar
White, same colour as the car. Hehehe even painted white under the hood lining too. It seems that Ford skimped painting under the hood lining on a lot of cars
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 24-04-2007, 08:00 AM   #34
Sledgehammer
Sledgehammer's Avatar
Originally Posted by b2tf
Looking sweet Aust.
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2007, 08:16 AM   #35
Sledgehammer
Here a red one for you. Still some more work to do though.
Old 24-04-2007, 01:12 PM   #36
StealthAu
Sledgehammer, thats sweet. How much rooting around was involved in dropping the 51 in there, and is it street driven?
Old 24-04-2007, 05:44 PM   #37
eXi7w0unD
eXi7w0unD's Avatar
i got red engine with a blue car..
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2007, 09:47 PM   #38
b2tf
b2tf's Avatar
swap ya stu
2024 F150 XLT
Old 25-04-2007, 11:55 AM   #39
walker
walker's Avatar
well I have a series 1 XR8 in white and that is the colour of my engine bay!
Its not peer presure..........Its just your turn!
XE project underway
walker is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2007, 12:24 AM   #40
Umineko
Karasu
Umineko's Avatar
Ok well as a spraypainter I can clear this one up, Ford in order to cut down on the number of coats applied in the paint process (something most other car makers do also) started using coloured sub base coats to improve the coverage of COB (clear over base) finishes, IE metallics and Pearls which tend to be quite translucent in nature. solid colours like white, black etc are not clear coated so the engine bays will be the same as the overall colour and usually a gloss finish, while metallics are a metallic or pearl tinted base coat which is overcoated with a clear finish, the engine bay receives the sub base coat but not the metallic base coat or clear gloss coat hence the "flat" finish and in some cases differing colours, were you to sand off the colour coats from your car you'd find the same colour over the entire vehicle by doing this Ford could drop about a kilo from the overall weight of the car and save a fortune in paint every year compared to previous models you can actually get mixing codes for these sub base coats should you wish to touch up the engine bay. say after repairs or mods and the surface sheen can be obtained by adding about 10 to 20% 2K hardener to the base coat mix, this will also stabilise the base coat and make it harder wearing
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2007, 11:46 AM   #41
DJM83
Barra Turbo > V8
DJM83's Avatar
My old AUII XR was Venom with a matt venom engine bay, my TE is galaxy with a black engine bay
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 11:09 AM   #42
AU dude
Flying high...
AU dude's Avatar
thanks Umineko, i can understand why ford would want to save money on paint even if its just $1 per car, times that by how many AU's were made.
