Old 10-03-2020, 09:52 PM   #91
Default Re: oil leak behind the accessory belt & pulleys
That’s basically what I did before fronting the sales counter. Checked material specs, and used the internationally recognised standards for size nomenclature against my measured sizes. Made the supplier’s job easy.
I checked each position’s fit individually to know each seal was acting as designed, and lubed everything with moly grease instead of petroleum jelly.
Citroënbender is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2022, 08:08 PM   #92
shyun
Originally Posted by Citroënbender View Post
Since the question comes up often and I am yet to see a concise answer that doesn’t involve Ford part numbers:
Tensioner assembly o-ring sizes for the AU, numbered per BS1806, a parallel industry standard. I suggest buying them in Viton or HNBR, not regular NBR.
013 filter basket, buy two
017 retainer nose, buy one
109 plug midlength seal, buy one
118 tensioner flange, buy one
Came across this and measured my o-rings since they are mostly stuffed and leaking too. They all seem correct except the 'Tensioner flange' (Ford P/N V 890066 S) should be BS 210 (ID: 18.64 S: 3.53 OD: 25.70)
ED XR6, LeMans Red, 5-Speed
AUII XR8, Silhouette, 5-Speed
shyun is offline   Reply With Quote Multi-Quote with this Post
