Old 27-08-2006, 11:08 AM   #91
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Use ATF in the box. It's the best stuff. Gear oil is too thick, and will cause the box to be notchy when cold, and damage it.
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 05:08 PM   #92
efgiar
rofl copter
efgiar's Avatar
i finished off my bros conversion today, eb 5 speed (series 1) and a jmm extreme clutch 900kg clamping pressure and goes hard, he just needs a spool now :P
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 05:23 PM   #93
kyro_02
V8 wannaabeee
kyro_02's Avatar
yes a mini spool is what he needs
his lsd is going to die a terrible death
kyro_02 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2006, 05:27 PM   #94
kyro_02
V8 wannaabeee
kyro_02's Avatar
here is some pics of the conversion process :P (supahstah's car)
http://www.putfile.com/kyro_02/images/6752
Old 30-12-2006, 06:12 PM   #95
atec77
Originally Posted by shuresm58
Oh, and when fitting the pin, easiest way is to use a set of vice grips on the clutch pedal shaft bit, and a 19mm spanner on the bolt. I spent a while figuring out how to stop the shaft from spinning while i was doing it up hehe
DO you have any photo's of this pin and install ?
Old 31-12-2006, 02:04 AM   #96
Christiaan
Christiaan's Avatar
Nah i don't
It's not hard, there's a ready made hole.
Just order the pin, bolt it to the pedal box, and away you go.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
