21-03-2016, 08:59 PM | #241 | |||
Still have to work out where to install it. Was going to go in the center under the rear view mirror but noticed the wipers don't cover that area and I'd prefer not to have it too low. I'll figure all that out when it arrives |
21-03-2016, 09:05 PM | #242 | ||
The best average I've been able to achieve on the freeway (M1, Sydney to Wyee and back with a bit of city driving) is 6.6l/100km. That's in a manual with the CC set to 115km/h.
To get lower I'd have to travel on a dead flat road and drive slower I suppose. |
21-03-2016, 10:04 PM | #243 | |||
11.5v is the only other option if I remember correctly. 12v is way too low for a battery.
That is how I had done it. You can buy these "Add on Circuits" for the fuse box. Goes in like a fuse, you place the original fuse into the first slot, and then you have a fuse slot for the added circuit and a good bit of wire to start from. For the Ground there is a 10mm nut behind the fuse box, just use a ring terminal. |
21-03-2016, 10:14 PM | #244 | ||
22-03-2016, 10:23 PM | #245 | ||
What type of driving were you doing at 212km a day, percentage motorway vs urban.
I am looking at LZ manual to replace my trusty LT diesel wh I is up to 241000kms. However the fuel consumption worries me reports on this forum indicate much the same as a 2006 2 litre petrol focus. No improvement in fuel consumption, fuel is a key for doing 1000kms a week |
23-03-2016, 08:20 PM | #246 | ||
Thanks for the pic. Yeap, I'll be using a fuse tap, just the one though. When you say you've used a ground nut behind the fuse box, does that mean you've removed the fuse box? Just looks a bit tight in there so I was hoping that wouldn't be needed.
23-03-2016, 11:18 PM | #247 | ||||
From what I can tell the killer of fuel is uphill and slow moving traffic. If you can set and forget the cruise control to a speed then you are going to save fuel. Tho that's a given. When you do drive it fast using higher revs and a lot of throttle in corners, you don't use much more fuel. 8.538L/100Km was Putty Road. Although the driving score was very low after that. |
28-03-2016, 01:26 AM | #248 | ||
Has anyone noticed symptoms of a rattling noise from the turbo similar to what's in this video?
https://youtu.be/81sO81hAfTU I noticed when I was in the garage the other day. Mine isnt quite as bad as the video, but just wondering if anyone else has it? The car drives completely fine, just sounds a bit rubbish.
LZ Ford Focus Sport 1.5 Ecoboost - Frozen White |
31-03-2016, 11:46 PM | #249 | ||
Hi guys, I've received and installed my dash cam (A118C - haven't hardwired it yet) and have noticed that due to the angle of the windscreen in these cars I'm getting heaps of reflections off the windscreen (can even see the reflection of the 8" display at night).
At first I thought the videos were grainy but then realised it's just the reflection of the 'grain' from the dash reflecting off the windscreen . I'm thinking of trying a dash mat but was wondering how everyone else who uses a dash cam is tackling this problem? Last resort will be a polarising filter for the lens somehow. Thanks, Norm |
01-04-2016, 09:14 AM | #250 | |||
You will need to find some way to mount the camera lens as close as possible to the windscreen. It sounds like you have it mounted high to be getting reflections from the 8" screen. The solution would be to mount it on top of the dash well forward and as close as practical to the windscreen. |
01-04-2016, 09:57 AM | #251 | |||
I've read a fair bit on different forums and a polarising filter helps but makes night time videos a bit darker. I'll try a dash mat and see how that goes. |
01-04-2016, 04:09 PM | #252 | |||
Another option (again, only if practical) is to fit some sort of makeshift lens hood. |
01-04-2016, 08:35 PM | #253 | |||
I think the main problem is I've only tested it going to and from work (heading east in the morning, west in the arvo) so I'm always heading towards the sun which is low in the sky during both trips . I'm sure it will be fine in the middle of the day with the sun high in the sky so I'll find out over the weekend. Still happy with it though, just have to run the cable across the roof liner and down the side of the A pillar to the fuse box and wire it in. Next mission will be when I install one on the rear window, have to dismantle the trim so I can run the power cable down to the rear fuse box Only 400km now to my complimentary 3000km service so I wont pull anything apart just yet |
01-04-2016, 08:52 PM | #254 | |||
I was just going to fit a cigarette plug on one of the rear trims and find an accessory power line.
2009 Ford Fiesta econetic - silver (sold 2012) 2012 Mazda6 Touring Wagon - silver (sold 2015) 2015 Ford Focus LZ Titanium - Magnetic (sold 2019) 2018 Ford Focus SA Titanium - white (current) |
01-04-2016, 09:58 PM | #255 | ||
Okay, I understand. If only a few millimetres, perhaps attaching a black card underneath the lens that extends to the windscreen?
01-04-2016, 11:28 PM | #256 | |||
As you can see, even the dash is in the image. I can point the cam up a bit but they say don't show too much sky as it effects the light exposure balance. Pretty sure a black dash mat will help a bit, just have to find a nice one. I've also attached inside and outside shots so you can see where it's mounted. I probably should have all this in the LZ Dashcam thread Last edited by NormM67; 01-04-2016 at 11:42 PM. |
01-04-2016, 11:55 PM | #257 | ||
08-04-2016, 04:21 PM | #258 | ||
Yay - adaptive cruise control, HID headlights and a sunroof option return to the Focus.
http://www.caradvice.com.au/432216/2...ew-tech-packs/ Now I can upgrade from my LW Focus Titanium with Sports Executive Pack. Last edited by PeCo; 08-04-2016 at 04:35 PM. |
08-04-2016, 06:45 PM | #259 | ||
got love adaptive cruise control ! Its like aircon was 20 years ago once you had it you would not go without
08-04-2016, 08:25 PM | #260 | ||
I have adaptive cruise control in my Trend. My right foot.
08-04-2016, 08:32 PM | #261 | ||
that must be like the early aircon when the window was wound down!
08-04-2016, 09:03 PM | #262 | ||
True, but you have to be careful when you jump back into a car without adaptive cruise. Forgot I was in another car and nearly ran up the back of another car on the freeway... oops
08-04-2016, 10:29 PM | #263 | ||
That's why I love driving a manual. Can't let the car make all the decisions for you
09-04-2016, 06:35 PM | #264 | ||
Hi all, am new this forum as have been in the market and researching various cars for the last 3 or so months and have to say these forums have been a great resource and assisted in the decision making process that saw me pay a deposit on a LZ Sport Auto in Winning Blue Colour today. I think I've got a good deal with; tinted windows, change the 17" alloy wheels to 5x2 spoke alloys, front & rear weather shields, front & rear mats, paint protection and extend warranty to 5yrs/100,000 Klm's for $30k. Am disappointed delivery won't be until mid to late June as wan't to be in the car now but all in all I'm happy with the purchase and look forward to being able to contribute to these forums, hopefully as a happy owner!
11-04-2016, 07:47 PM | #265 | ||
11-04-2016, 08:02 PM | #266 | ||
Yours in the photo in your profile looks great, did you change up the wheels? I was tossing up between the Winning Blue and Frozen White but the Blue really catches the eye. Was a bit worried the Blue wouldn't look as good in real life as it does in brochures as have seen a darker/duller, more solid Blue on Focus getting around but may be an older model? Not too fussed about just missing out on SYNC 3 as more interested in the drive rather than the gadgets (although there are plenty off good ones!).
11-04-2016, 08:04 PM | #267 | ||
[Congrats mate. I'm biased but Winning Blue is the nicest colour. Looks like you got a great deal too ]Yours in the photo in your profile looks great, did you change up the wheels? I was tossing up between the Winning Blue and Frozen White but the Blue really catches the eye. Was a bit worried the Blue wouldn't look as good in real life as it does in brochures as have seen a darker/duller, more solid Blue on Focus getting around but may be an older model? Not too fussed about just missing out on SYNC 3 as more interested in the drive rather than the gadgets (although there are plenty off good ones!).[/QUOTE]
12-04-2016, 12:24 AM | #268 | ||
Hey Pman, nah, the wheels are just standard Trend mags.
I actually think the colour looks better in real life than in the brochure, especially after a good wax and in the sun That blue really stands out in the carpark at work where 80% of the cars are either white or silver I wouldn't be too worried about Sync3, Sync2 does everything (and more) that I need it too. Just take a little time setting it up (voice tags for Navigation for example) and you'll find your doing nearly everything by voice anyway. The only thing I cant do is control the climate as I only have a Trend so have manual A/C. Not that it matters as it's not something I'm continually playing with. Fuel usage isn't as good as I thought it would be but it's such a pleasure to drive that the driving experience makes up for it. Last edited by NormM67; 12-04-2016 at 12:45 AM. |
12-04-2016, 12:46 AM | #269 | ||
I have just come back from a trip down to Ulladulla (from NW Sydney) the first really long trip in the car. It was a great drive and I'm just getting more and more impressed with the car.
Fuel consumption wise, I got 5.8L\100 on the way down (conservative with the throttle and no air con). Was siting right on speed limits. On the way back air con was off most of the way, and was a bit more throttle happy and got 6.5L\100 (pushing my luck with speed limits on the dual carriage ways ;) There were two people in the car with two suit cases and food supplies (a full boot and partial back seat), so I'm pretty impressed. The car does seem to love the open road a lot more than the city fuel consumption wise, especially with the automatic.
12-04-2016, 08:28 AM | #270 | ||
Now that the upgrade and other options have appeared, I will be looking at a new LZ Titanium later in the year.
Question - is there any delay or lead time experienced in the supply of vehicles or are they readily available? |
