17-11-2005, 02:22 PM | #1 | ||
Hi,
Curious to know what RPM does a Focus ST170 sit on when cruising along the highway in 6th gear at 100km/h? Thanks in advance |
17-11-2005, 04:59 PM | #2 | ||
At 110kph it's 3000 RPM
17-11-2005, 05:05 PM | #3 | ||
From memory 36 KPH per 1000 RPM was in the Spec sheet
But above Post is from driving to work each day |
17-11-2005, 05:43 PM | #4 | ||
Cheers Stampy
18-11-2005, 02:23 PM | #5 | ||
Whats the final drive ratio? ie, the diff ratio? 6th would be an underdrive gear so it sounds like around 4.11 under there or something
18-11-2005, 05:32 PM | #6 | ||
Anyone own an ST170 on here that can tell me 1st hand?
18-11-2005, 05:48 PM | #7 | ||
Windsor Man!
6 gears in a focus!?!?!?!
Wife's car - BA XT Wagon - Lowm shiney wheels, dark tint, no bottom half of front bar, faded paint :/ My Car - 93 Diesel Lux - not as fast but more reliable than her falcon! |
18-11-2005, 09:00 PM | #8 | ||
WRC Fanatic
The 6th gear ratio is 1.09:1 and the final drive ratio is 4.25:1. Stampy is right too, it revs at around 3000 rpm at 110km/h. This is much higher than you would expect from a 6 speed, but 3rd 4th and 5th are relatively close together and I’m guessing that the final drive ratio is almost the same as the normal focus 5 speed. It has its advantages though because you can use sixth quite happily from 80 km/h onwards.
Just an extra bit of info, I have achieved 43 mpg (6.5 l /100km) with a slight tail wind and driving conservatively. Normal highway economy is around 38 mpg though. Not bad for a performance car I thought.
Panther Black XR5T Pro Alloy Intercooler| Angel Eye Headlights (black)| Eibach Prokit Springs| K&N Gen II 57i CAI|
Dreamscience| InPro Black LED Tail lights| Black RS GT wheels| 14.007 @ 100.55 mph |
19-11-2005, 12:40 AM | #9 | ||
Tricolore Tard
Have to disagree here.
Checked tonight on the way to work, in 6th im pulling 2700-2750rpm 3000rpm is doing 110kph Chris
19-11-2005, 12:55 AM | #10 | |||
WRC Fanatic
19-11-2005, 01:31 AM | #11 | ||
Tricolore Tard
Well that will teach me to read forums when I have had no sleep since finishing work at 7am :(
19-11-2005, 02:59 AM | #12 | ||
Zoom Zoom
Out of interest, we're on about 3,000rpm at 100km/h in the 5spd Manual 2.0 Zetec and 3,100rpm or so at 110km/h. I have averaged 7.4L/100km on roughly 110km/h on the highway but have nevr tested it to get it as low as possible. Peronsally I find it stupid and always feel (even after 3 years) that I have another gear to grab because 5th is geared so short. If it spun at 2,600rpm at 100km/h I'd be much happier. Performance is OK, it's really just a shortish gearbox covering for a gutless engine. ST170 is pretty much te same thing, just one extra ratio, still covering up for an otherwise unremarkably powerful engine. The graring in both cars works, but it's strange to ger the top gears in each so high. When on Earth would you EVER need a short 6th gear?!!!!!! Defies logic.
2012 Mazda3 MPS
20-11-2005, 01:40 AM | #13 | ||
not here much anymore
3100 @ 110km/hr in a 2L Auto Focus. :
RAM 1500
21-11-2005, 04:27 PM | #14 | ||
Old enough to know better
Just checked my 2.0 litre Zetec up and down the Eastern Freeway.
2600 rpm @ 100kmh 2900 rpm @ 110kmh Checked it 3-4 times
21-11-2005, 07:05 PM | #15 | ||
Zoom Zoom
Stephen don't htink it might be your alloys being a different diameter? Shouldn't be that different surely!! I can guarantee mine's above 3,000rpm at 110km, but I'll check tomorrow using the digital odometer check
2012 Mazda3 MPS
