Old 17-12-2016, 07:36 AM   #1
Markwa
Default WT service specs
Hi all.
I am going to start servicing my WT 1.6 petrol myself and unlike all the cars I have owned in the past this one comes with a rubber type oil plug gasket. Unlike the old copper ones I am used to I am worried ill over tighten it and split it so anyone know the correct torque on the oil drain plug? I have a small torque wrench so might as well do it right
Also I am going to switch to Penrite HPR5 5w40 oil because I don't like the castrol oil Ford dealers use so anyone else use this in there fiesta?
Last thing is what is the best spark plugs to use and part numbers if you know them. I used platinums in my old car and 10 years latter they are still like new so I think ill go down the same path with this car unless people have had issues with other types of plugs.
Thanks for any advice.
Markwa is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2016, 10:12 AM   #2
GTLEGEND
Default Re: WT service specs
Sump Plug 27 Nm
I always use genuine Ford plugs.
As for oil, CASTROL MAGNATEC 5W-30 A5.
Old 17-12-2016, 05:38 PM   #3
DZFord
DZFord's Avatar
I used NGK PTR5A-13 platinum plugs on my wife's Fiesta with the same 1.6L Duratec engine and haven't had any issues
Old 18-12-2016, 12:02 AM   #4
GTLEGEND
Ford Plugs 4M5G 12405 AA...
Old 18-12-2016, 06:41 AM   #5
Markwa
thanks for the replys. 27nm almost sounds too much for a rubber o-ring type oil plug washer but I guess they make them out of material that wont split like a normal rubber one would.
Anyone use ryco filters? I could not get a genuine one the other day and after seeing it's made in china I am thinking ill keep it for a spare and find a genuine one. Do the genuine oil filter have a anti drain back valve? I was thinking they don't and I don't like the idea using something different.
Funny how I service my old car for 18 years but now im worrying about doing this one lol.
Old 18-12-2016, 10:36 AM   #6
GTLEGEND
I only use Ryco when the genuine is not available, but the genuine Ford for 1.6 Petrol WT Fieata EM5G 6714 AA is only $10, why would you even consider aftermarket, best for piece of mind.
I am think the anti drain back is in the oil pump, not the filter, but could be wrong.
