Boss 335
Noticed a burning sulphuric smell and lifted the bonnet to check. To my horror the terminals were smoking and the battery was extremely hot. I know the battery isn't the best as it was sitting discharged for a very long time, but is this likely to be a problem with the battery or the car itself ?
Boss 335
Is it ok to run the car without battery to drive it to get fixed ?
Boss 335
Hooked the car to a multi and its reading 14v. Would it be the alternator ?
![]() Join Date: Nov 2006
[QUOTE=malazn mafia;5888803]Hooked the car to a multi and its reading 14v. Would it be the alternator ?[/QUOTE**
Doubtful.
The Stable. AU II XR8 Daily driver. BF XR8 ute (Red the only true Modification) ![]() The boy, XT Ute 393 cleveland. Genuine XB GT. |
No, You could do a lot of damage to the electronics of a modern car. Recently I disconnected the battery for on a 40 year old car while it was running and managed to blow a diode in the alternator in a few seconds.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
wouldn't be a century battery by any chance?
Boss 335
It's an exide. Bit the bullet and drove with no battery, with no consequence. Fitted new battery and all seems ok, will keep an eye on battery temperatures. The voltage gauge reads spot on 14.5V, regardless of RPM, so the alternator must be good ?
Performance moderator
![]() Join Date: Feb 2005
Could be suspect Regulator ? Alternators can over charge if battery cell is down too..
#10 | |||
Experienced Member
2 users like this post: |
Boss 335
#12 | ||
a lot of so called maintenance free batteries do need a look at,false advertising.
Boss 335
#14 | ||
Funny thing with FG GT it just wont start or have ignition if battery is suspect !! My one started in morning . Then when restarting at school it had dead battery.. After fitting new battery .. All is fine.. The local Repco guy said he needed to order in a special FPV battery..Bought a good battery down the road for $140...
#15 | |||
Boss 335
#16 | |||
If battery is dead or close to it, does take some time to start.
Before - ED Falcon Futura (sold) EL XR6 (R.I.P.) VX SS (R.I.P) VE Berlina |
#17 | ||
Yes it SEEMS like ECU is controlling battery output.. It started fine in morning.. Then after 10 min drive, 20 min being turned off... Even with jumper leads on 200 A/H battery.. NO elect feed, connections are good.... Fitted a new battery..FIXED !! I guess its there to prevent things suffering from low amps? .. [ Low volts requires higher amps to do same job, always propotional] As said seems to have built in breaker ? The reds or lights didn't work either.. Newer starter motors have gear reduction for light weight high torque..
#18 | |||
GT-P With An Ego
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
#19 | ||
Cruising...
I had this same issue in my outback. Having twin batteries, my smaller one started to smoke and burn. Disconnected it, got a new one and it was all good after that.
When the battery doesn't want to live anymore but hasn't dropped cells, it'll overheat.
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
#20 | ||
Anyone need to replace their battery?
I've got a Century Hi Performance 57EF 540CCA for sale if anyone wants to save some bucks. Still has 16 months full replacement warranty. . . . Last edited by winlucky; 03-03-2017 at 11:54 PM. |
#21 | ||
I had a battery once that was a NRMA battery but wasnt right and would make a hissing noise when charged from car or charger.
Took it out and let it discharge and disposed of at recyclers Never ever heard a hissing battery before
