14-03-2010, 02:28 PM | #1 | ||
Morning all
fixing a brake problem on a 95 Festiva the pedel is almost to the floor before brakes work (if not on the floor!) I have removed the booster, not sure how to tell if its ok??? brake pads etc look ok any ideas? Tro
What good is imortality if you dont test it once in a while |
14-03-2010, 04:07 PM | #2 | ||
Booster is fine, tested
not sure about the Master Cylinder?? the piston return spring I can feel when pushing the piston in by hand could the rear drum brakes be not adjusting properly??
