FPV & XR Club of Victoria Discussions FPV & XR Club of Victoria Discussions |
11-08-2007, 06:12 PM | #1 | ||
MIGHTY MAGPIES 2010
Location: yarram se vic in the shed listening to pinkfloyd and rubbing panels
so got an xr6 ef and it is using lot's of fuel and exuast tip is black but car not using oil and it still goes hard any one know what the problem may be re using fuel
11-08-2007, 06:48 PM | #2 | ||
have you done anything to it lately. Radiator thermostat
cheers
Ambrose driving in Nascar and joining RPM Murphy somewhere in the V8'S. XR6 Turbo.Championship winner. |
11-08-2007, 08:19 PM | #3 | ||
MIGHTY MAGPIES 2010
dont mean to sound silly but what does the radiator and themostate have to do with the fuel system
12-08-2007, 04:11 PM | #4 | ||
First way to get stuff fixed is answer the questions because I don't have all day to mail back and forth.
The thing about rad and therms is heat if the car isn't getting hot enough quick enough it thinks it's still cold and runs on cold settings kinda like running around on the choke all day. While this may not be consistant with your model it is overlooked time and time again. Things as simple as fitting a heavey duty radiator with out the correct therma can cause a huge fuel prob. cheers
12-08-2007, 08:51 PM | #5 | ||
MIGHTY MAGPIES 2010
so that could be the problem then i have noticed it does run cold and sorry i didn't answer your ? as i am a little ignorant of the later model car's it's a ef 6 fuel injected tickford motor and as i said using lot's of fuel and to answer your origanal ? i hav't touch iit only the usual service's buy the local garage
