Old 18-02-2006, 02:32 PM   #1
hobo
Monster Burreuto
hobo's Avatar
Default Distributer is driving me to drink!
Haveing ИИИИloads of trouble after changing a distributer in a 3.9, i have got the new one in and have been trying to get it to start for a day and a half. all i can get is a backfire occasionly. i have it at TDC with the arm button dealy pointing at finish. for the life of me i cant get it to start : can someone help me or tell me how to do it, or even some pics from a workshop manual?
I PITY THE FOOL :ticking:
hobo is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 03:02 PM   #2
MAD
Petro-sexual
MAD's Avatar
Is it CFI or multipoint?
Are you sure the dizzy is not 180deg out? Also, double check your spark leads.
- The Story
Old 18-02-2006, 03:18 PM   #3
blu falc
acclaimed user
the rotor on the mpi ones are different to the cpi ones so that may be the cause of your woes
blu falc is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 03:32 PM   #4
hobo
Monster Burreuto
hobo's Avatar
multipoint, and the other distributer is off a multipoint aswell. what do you mean 180 degress out?
Old 18-02-2006, 03:37 PM   #5
EAman
Ea 1990 with ef head
EAman's Avatar
Location: recently relocated from gipsland to newcastle
the rotor button might need to be turned back 180 degrees
EAman is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 03:39 PM   #6
hobo
Monster Burreuto
hobo's Avatar
it only seems to go one way
Old 18-02-2006, 03:54 PM   #7
gthofan
Gunna girlie-man
gthofan's Avatar
is the car backfiring out the exhaust, or out the airbox/airfilter??
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 04:10 PM   #8
Damo
are you sure it's on TDC on compression stroke ?
Old 18-02-2006, 04:48 PM   #9
MAD
Petro-sexual
MAD's Avatar
What I mean is that you might have the engine on TDC but on the exhaust stroke, not the compression stroke.
- The Story
Old 18-02-2006, 04:57 PM   #10
hobo
Monster Burreuto
hobo's Avatar
ok, can someone tell me how to set it on the right stroke? and it was backfiring out of the airfilter, it;s all in peices again now though.
Old 18-02-2006, 06:49 PM   #11
hobo
Monster Burreuto
hobo's Avatar
ok i tried turning the rotor 180 degrees, but the mark on the balancer isnt showing up with the timing light. so i must of had it right before, i have got the mark ligned up with the IGN mark on the balancer, i have also tried a bit before and after that but still no fire. what the F-king hell is going on?
Old 18-02-2006, 07:51 PM   #12
Papa Smurf
Papa Smurf's Avatar
IS this Distributor NEW or another one? Have you made sure ALL the connections are clean and pushed home properly? are the Plug Leads ok? Is the connection to the coil plugged in properly?
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 08:04 PM   #13
MAD
Petro-sexual
MAD's Avatar
To set the dizzy properly you must remove it from the block, turn the engine to TDC (on compression stroke for cyl #1) re-seat the dizzy and align the 'finish' mark with the rotor.
Are all your spark leads connected correctly?
- The Story
Old 18-02-2006, 08:34 PM   #14
hobo
Monster Burreuto
hobo's Avatar
distributer in a second handy but was working fine on the old engine. as far as i can tell everything is connected properly and i am getting spark to all cylinders, but one thing is i can hear the injectors clicking and can feel the pressure in the fuel line but my plugs are dry. i will pull the fuel rail out and see if there spraying.
