Old 22-02-2020, 11:52 AM   #1
Rural 351
1000+ passes
Rural 351's Avatar
Default 1972 1600 Capri engine number
Just a quick question I’ve been searching and still not sure about the engine number location on a Kent 1600 in a 1972 XL Capri, I was about to do an engine swap cause I thought my Engine didn’t have a number so it wouldn’t matter since it was a non matching car, But now I have located the matching number on the front of the block just under the head, is this normal I was under the impression it should be on the side above oil sensor. Thanks in advance Bruce
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph
https://www.facebook.com/DragRacingT...2067110055900/
http://www.cacklingpipes.com/100825_...250810_025.JPG
XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph
The faster youve gone the worse your attitude
Rural 351 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2020, 12:19 PM   #2
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Default Re: 1972 1600 Capri engine number
Try here, theres a lot of Capri guru's/ anoraks that'd be able to help
https://www.classic-ford.org/cfp/
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 24-02-2020, 11:58 PM   #3
Capriman
formerly ford3000gt
Capriman's Avatar
The engine number on 711M blocks is at the front of the head, right where you found it. Earlier 691M blocks had the number on the side from recollection. You've answered your own question as you have matched it to the chassis number and 711M blocks are the best 1600 blocks, as used in Formula Fords. Cheers, Terry
Current ride:
'83 Mk.3 Capri, 2.8i, 5-spd
Capriman is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2020, 02:50 PM   #4
Rural 351
1000+ passes
Rural 351's Avatar
Thanks Mate looks like I will rebuild the original motor,
Old 04-11-2020, 09:39 AM   #5
Changa
Changa's Avatar
Hi All,
I am looking for my engine number. I have a 67 Cortina 440 that is running a 1600 Kent X flow 711 engine. Earlier engines had the number near the dizzy, badly stamped into the cast block very hard to read. I see that the later 711 engines have engine number in diff location.. Any chance someone could post a pic of the EXACT place to look for my engine number please?
TIA
Changa is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2020, 11:05 AM   #6
cosworthfreak
cosworthfreak's Avatar
Hopefully this picture attaches properly. This is the location for all 1600 Kent Ford engines pretty much. Unfortunately, if the mating surface ever gets skimmed for a rebuild the numbers can be skimmed off as well.
File Type: jpeg E6B4F477-176A-4232-BB54-9CA2AAFA222B.jpeg (111.5 KB, 13 views)
cosworthfreak is online now   Reply With Quote Multi-Quote with this Post
Old 04-11-2020, 11:11 AM   #7
Changa
Changa's Avatar
Thanks mate. I had my suspicions it was supposed to be there.
My engine was recently rebuilt and obviously skimmed.
Thanks again
Seeya ! Wouldn't wanna be ya !
