Old 12-10-2022, 07:34 AM   #1
Default Flaky DMM on DC Voltage
My meter is a good 15 years old, it cost me $80 back then. Auto-ranging with extras of temperature, capacitance, inductance, transistor testing. I’ve barely used the last two aspects but otherwise it gets a flogging. The temperature (with k-type probe) is great for thermostat checking on the bench.
Lately it’s become increasingly unreliable when measuring DC voltage. It has long had the odd vague-out on resistance or continuity but usually twisting the dial a couple of times and/or pressing Reset, fixes this. DC volts, though, unless it’s a strong source it is no longer giving a sane reading.
Technology price-points have shifted, I could replace it for $70 with a meter that does everything the same except inductance and transistor checking. Before I do that - has anyone experienced similar malfunction and resolved with a repair?
Old 12-10-2022, 02:51 PM   #2
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
Default Re: Flaky DMM on DC Voltage
Perhaps change the battery, clean the terminals with a cotton bud and isopropyl in case you have some oil or gunk in there, check the range switch too.... then bin it. If you can't trust it, you can't trust it.
Funnily enough my worst meters for reliability have been Fluke. The $50 to $150 meters seem to go forever.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 12-10-2022, 04:19 PM   #3
Have you swapped out the leads for known reliable ones? Even a second set might give you a clue its not the meter (edit - though it looks to read non-DC without issue)
Old 12-10-2022, 06:39 PM   #4
Have you opened it up and:
Checked for dry joins especially around where the sockets for the test lead are solder to the PCB;
Checked the tracks of the selection knob are making good contacts with the knob and are not worn away;
The batteries have not leaked and corroded anything; and
there are no smoke marks or other indications of component failure?
Old 12-10-2022, 08:51 PM   #5
Have pulled it down and visually checked.
All solder joints look fine. Processor has black epoxy security, this does not seem to be chemically decomposing.
The double-ball dial detent has been weeping grease onto the circuit board, possibly contaminating the wipers and their tracks. I lightly buffed the wipers with grey Scotchbrite, thoroughly cleaned them and the tracks with wax-and-grease remover, cleaned the LCD signal contacts with alcohol, reassembled. Just another evening of stuff you do when TV isn’t in your life…
Now to test it!
Old 13-10-2022, 12:13 AM   #6
Well, it’s definitely no worse. I really need daylight to confirm - but it may be fixed.
Old 13-10-2022, 12:58 AM   #7
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
I have a Digitech meter that doesn’t read DC volts at all now. Luckily I have replaced it with one that does more, like reading frequency. I’m not sure what to do with the faulty meter… label it AC only? Or for continuity checks , and AC if you dare. Either way I might make a DODGY label for it.
Swanny’s Fundraiser for the 2024 MS Brissie to the Bay 100km Bike Ride
2016 Ford Falcon FG/X XR6 Turbo you beaut ute
1985 XR4Ti Sierra - Build Thread
1971 Fairlane 500
and... a collection of Jeep Towpigs
and... two collections of rust and some new plastic bits roughly shaped like an F-Truck
and.... some spare metal bits with holes in them
Captain Stubing is online now   Reply With Quote Multi-Quote with this Post
Old 13-10-2022, 05:18 AM   #8
Sounds a very modern meter; it has replaced facts with opinions.
Old 13-10-2022, 06:27 PM   #9
Itsme
Experienced Member
Itsme's Avatar
Why would you bother with it, bin it and get a quality replacement.
Old 13-10-2022, 11:40 PM   #10
I’m pretty tight with some things. It doesn’t provide data which directly affects health and safety items, the most common use is continuity/resistance followed by DC volts. So, if it’s been scrubbed up sufficiently to rely on for these tasks - I’ll save my $69 for now.
Old 14-10-2022, 03:20 PM   #11
Itsme
Experienced Member
Itsme's Avatar
Fair call; but for me accuracy is a must otherwise inaccurate readings does not cut it when it comes to testing circuits & components.
Old 16-10-2022, 08:02 PM   #12
zilo
BANNED
zilo's Avatar
Digitech? .... am surprised it lasted this long....
Please press the "Like" button if you enjoy my posts.
(It's the red triangle with exclamation mark on the left)
zilo is offline   Reply With Quote Multi-Quote with this Post
