xw ute
I have a standard 351 with four barrel manifold, but runing a 2 barrel want 2 put 4 barrel on. But not sure of size any idea?
Hmmmmm Mulberry....
Found a 650 DP to be good. Had a 750 VS on but the 650 was better.
Hope that helps |
#3 | |||
Previously ScottishXC
I asked the same question a while back....had a lot of responses but the overall opinion here and elsewhere is 600vac sec is plenty for a stock 351. Yes, there are plenty of stockos running 650dp's and bigger that work but apparently you run the risk of pouring too much fuel down the bores and washing off the oil...not healthy. OR, you size the jets down on the larger carb...bit defeatist really!
Are you running 2v heads? Mine has a 600vac sec as advised and seems fine- great improvement on the 2 barrel! Here is the thread I started- much of it refers to the thermo fans but as you get into it, thecarbs gets a few good mentions too. Hope this is useful! http://www.fordforums.com.au/showthr...4&page=1&pp=25
Great transactions with the following members: BJ Gilesie XAGTCoupe Pilch Aussie_afroman Donut King Bad Boy Benny BAWITHLOT Greenmachine Pinkbits CUZ351 OhioXB Falconunbelievable 4VXC Uncleraggy FG G6 Ego, tech pack, Tropic gold 1973 Landau, Cosmic blue 1975 P5 LTD....long term project Quote:
Go for a Holley anything from 500 to 650 with vac seconds will be fine.
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
BLOWN 383 CHEV OWNER
Speak to your engine builder or mechanic but 650 sounds like a good size.
#6 | |||
buickman
