26-07-2019, 12:06 PM | #211 | ||
Shockwave
3 users like this post: |
26-07-2019, 05:41 PM | #212 | ||
XR6T BA 2002
Cool Thanks for the reply
Sounds good Will Stock BA Brakes front and back just bolt on ? I am getting the safebrake stainless Lines
XR6T 2002 BA
14-08-2019, 08:01 AM | #213 | ||
for those that are thinking about territory rear brakes
here are some photos on fitment first photo is no spacer behind the mounting bracket you can see the rotor touches the bracket this one is 2mm washers fitted, still no room this is with 2 washers (4mm) and it rubs on the other side and here you can see the stock backing plate touches all over the place
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
01-09-2019, 06:46 PM | #214 | ||
So I think I’ve got it now, I’ve read this enire thread..
1• AU S1 had a master Cyl Change in late 99 to a bigger bore, this is the master required for FGT 322mm front brakes and Territory 30? rears to match the extra volume required? 2• Need lower control arms, uprights, hubs, swaybar links & brackets from AU S2-FGX with BF brake lines and caliper bolts to match the above brake upgrade.. 3• Territory brakes go on IRS rear with 3mm spacer to center the caliper and require the Territory rear back plate with custom brake line to suit? 4• Territory brakes on solid axle bolts up and also required custom brake line How did I go?
Previous Fords TD Cortina 250 6cyl 4 speed (stolen) MK 2 Escort 2ltr Pinto 5 speed Celica box (written off) XE Falcon LPG Turbo 2k stall C4 Auto (Tboned) XF falcon Fairmont stocker (Expired) TF Cortina 250 6cyl (parted out) 2011 Manual GS 399rwkw (sold) 2011 AWD Titanium Seduce (sold) My Fords 1998 AU S1 V8 Fairmont Wagon Regency Red Daily Kenworth T604 36" bunk Full house C15 & 18 Gears 820hp @ 1700 2600ftlb @ 1450 |
01-09-2019, 08:47 PM | #215 | ||
So in my case my march 99 au1 6cyl most likely has the small master cylinder and i have no issues running the big brakes, they almost pull your face off. The bigger master cylinder might give a better pedal feel but in my case its not required
The AU2/3 front brake lines will fit on BA 298 and 322 calipers but using BA lines would be best as it has a longer bent hardline at the caliper end Rear territory calipers on a live axle can use AU lines no problem as thats what im using
01-09-2019, 09:37 PM | #216 | ||
How many guys on here have gone the premium brake upgrade on the front -328mm I think from memory... Would there be much benefit over the 322mm rotors? I think the 328mm are a fair bit thicker too.
01-09-2019, 09:42 PM | #217 | |||
T-Series Club Member Vic
01-09-2019, 10:16 PM | #218 | ||
Yeah they look good silver!
Do you know how you would tell the calipers apart between the 322 and 329? You probably wouldn’t pick up 7mm difference unless you had both rotors next to each other. But is there anything on the calipers to identify them by? |
01-09-2019, 10:38 PM | #219 | |||
You can't stop the signal
You can identify the calipers by looking at them.
It is all to do with the cooling fins & the front face 322mm BF 322mm caliper 28mm thick disc 329mm - AU Premiums - Also C4 corvette caliper Distinction is in the round mounting holes in the face of the caliper 28mm thick disc 325mm - BA Premiums - C5 Corvette caliper Flat face, cooling fins at top only, central divot 32mm thick disc
5 users like this post: |
01-09-2019, 11:05 PM | #220 | ||
Thanks Superroo
They are pretty easy to identify after looking at them like that. The au premiums never come up and every one wants so much for them. I’m going to try and find some of the ba/bf premiums, just for the thicker rotors, my Mrs warps the standard au fronts every time she drives it haha. |
08-11-2019, 07:47 PM | #221 | ||
Thread mine!!
Has anyone put Safebrake braided lines on the AU2/3? On the rear calipers the brackets supplied with the hoses dont face in the right direction. Did anyone else have this problem and how did you get around it? |
31-12-2019, 10:09 PM | #222 | ||
What have people used for brake lines when using the territory rear calipers on an S3 IRS? Or do the factory lines fit?
Regards 5LXHR8 Daily- AU 2 Fairmont Wagon V8 Toys- T3 TS50 build 211 - 67 XR ute Last edited by 5LXHR8; 31-12-2019 at 10:21 PM. |
02-01-2020, 02:21 PM | #223 | |||
Next upgraded Mk1 Leopard
I used Standard AUIII lines and also from BA Ute (they have the same/similar cable mount) UK
21-07-2021, 02:38 PM | #224 | ||
Gidday fella's, I've read through the thread but can't find an answer to my question - do I need to change the brake booster/master cylinder for my particular upgrade?
I've got a S1 AU Ghia that I want to put BF turbo brakes on; stub axels, sway bar, control arms have been done. Anyone know if I need to upgrade the booster and master? Cheers.. |
21-07-2021, 02:55 PM | #225 | |||
however a booster will help and will help with lazy city driving when you use your big toe to brake. so to answer your question: its good to do it but not mandatory at all.
21-07-2021, 06:29 PM | #226 | ||
Thanks mate, handy to know that..
21-07-2021, 06:33 PM | #227 | ||
Interesting thread what is the best front/rear I can on a AU2 with 18 inch speedlines
2001 AU2 220 XR8 - Build thread |
21-07-2021, 06:43 PM | #228 | |||
#neuteredlyfe
If off the shelf then the same as what I have. 322mm XR6T/XR8 brakes on the front (excluding BA). 328mm BFI XR6T/XR8 or Territory brakes on the rear. NOTE: BFII went back to the standard 303mm brakes on the rear. |
21-07-2021, 07:13 PM | #229 | |||
22-07-2021, 09:09 AM | #230 | ||
Afterburner + skids =
I'd love to get some solid intel on what length brake lines are needed for the rear Territory upgrade. Some say the standard lines are long enough, others say they need to be replaced with longer ones. I will be getting braided lines made up, so obviously they can be whatever length i want.
Does anyone have a definitive answer on this? Actual measurements of the line would be extremely helpful.
22-07-2021, 10:01 AM | #231 | |||
22-07-2021, 10:35 AM | #232 | ||
Sorry, I should have clarified, my question relates to IRS.
22-07-2021, 12:27 PM | #233 | ||
I have standard BLs on my XR 8 to Terry rears.
25-07-2021, 09:48 AM | #234 | ||
Just confirming for the 328mm rears there are no mounting brackets?
So the caliper cradle bolts straight on?
25-07-2021, 10:57 AM | #235 | |||
UK
25-07-2021, 12:50 PM | #236 | |||
As mentioned use spacers to get it sitting centred over the disc. A good way to see for yourself what is required is to remove the caliper bracket from the caliper body(the body being the bit with the piston). Then you bolt the caliper bracket on by itself with the disc on, and it becomes quite obvious where it has to live to be centred over the disc, try get the same space on each side of the bracket where its cut out to fit over the disc. 3mm is about right, rolan on ebay sells ARP brand hardened washers which i like, some generic washers arent so great, it depends, you just dont want ones that are soft and crush etc. when torqued. |
25-07-2021, 01:13 PM | #237 | |||
Just got ordered a set of refurbed terry 328mm rears. Think I will contact race brakes sydney to see if they can make up some new lines for the rear. Fronts seem to be elusive as of right now I did see RBS sell a 325mm front kit same as on the ba gt.
25-07-2021, 01:19 PM | #238 | ||
Genuine 322 fronts getting more difficult to find, there are the aftermarket brackets on ebay
https://www.ebay.com.au/itm/263136426361 https://www.ebay.com.au/itm/283709614621 Then can use any BA caliper, swap the brackets with the new ones, it is the brackets that are different on the 322, rest of caliper is same as the regular BA. |
25-07-2021, 01:25 PM | #239 | |||
25-07-2021, 01:38 PM | #240 | |||
Those mounting brackets, correct rotors/pads and new lines would work?
