Old 19-09-2009, 11:34 PM   #1
fourl6
AU Falcon Man
fourl6's Avatar
Default AU 2-3 High Series Cluster Upgrade
I know this has been covered a million times but some of the main things have never been answered, I changed my AU3 Forte cluster to a AU3 Fairmont Ghia Cluster today, all working great, only thing is that i dont have a trip meter as the high series have it in the climate control? and havn't wired up the individual door ajar and the washer fluid senser
all the tec docs around give basic instruction on upgrading a series 1 and just say change this these pins, not very easy to understand
the instructions for series 1 are pretty much the same for 2/3 with one of the wires changing colour but all pin locations staying the same
The following wires need to be moved around, in order for the Mid/High Cluster to function correctly,
1. The Park Lamp Dial (+ Positive) Illumination needs to be moved from Pin 13 to Pin 2. - Brown
2. The Dial Negative Dimmer Illumination needs to be moved from Pin 21 to Pin 3. - Light Blue / Red
3. The ABS Warning Lamp Wire needs to be moved from Pin 8 to Pin 23 - Orange/Black
4. The R.H. Side Indicator wire needs to be moved from Pin 19 to Pin 26 - Green / Light Blue (Series 1 is White / Light Blue)
(Using the Photo Below) The Pin numbers start from bottom right and go in a U shape to the top right spread over the 2 connections, so a total of 28 pins one connection has 8 pins (that does not exist on base model wiring) and the other has 20 pins
this photos is of the back of a AU3 Fairmont Ghia Cluster with a AU3 Forte Wiring loom, with the pins removed from the connection
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2009, 09:32 PM   #2
fourl6
AU Falcon Man
fourl6's Avatar
correction... i do have a trip meter, but no dte...
Was
Old 21-09-2009, 08:29 AM   #3
Mont5.0
Mont5.0's Avatar
DTE will be found on the left hand side of the climate control display.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2009, 01:29 PM   #4
T3man
T3man's Avatar
On a Forte? Don't think so. In fact I'm pretty sure you won't even find CC display.
Old 21-09-2009, 03:33 PM   #5
ronwest
All Bran = Regular Member
I don't know either but according to the "Instruments" section here http://www.trueblueford.com/AU1_intro_INTERIOR.html all AU Falcons came with DTE.
ronwest is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2009, 03:58 PM   #6
NC1183
NC1183's Avatar
Yeah, all AU Falcons came with DTE, however, the Fairlane and the T-Series except T3TE had it displayed in the centre console along with the climate control and fuel usage displays. The Forte, XR and T3TE all had it on the dash cluster.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2009, 04:04 PM   #7
brad`
The Monty
brad`'s Avatar
also all fairmonts had it on the climate control, all series
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2009, 04:43 PM   #8
fourl6
AU Falcon Man
fourl6's Avatar
so mine being a forte with a ghia cluster, it no longer displays dte, still beeps when low on fuel. i wonder how harrd it would be to wire up the climate contol screen (just to display fuel usage etc.)
just had a look at the wiring diagram of the cluster and the nothing special the there... just door open wires etc...
Was
Old 22-09-2009, 08:14 PM   #9
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
im sorry for hijacking the thread mate ive got an au2 futura does this mean i could use the au2 monty cluster, as i crave the oil and volts metres?
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2009, 08:53 PM   #10
NC1183
NC1183's Avatar
Yep, that is correct, either 'mont or XR cluster will go in, just need to change pin locations etc according to diagram, and then either get Ford to disable the Rad and Washer level lights or connect the sensors
Nathan
The SP
The old ute (sold)
Build Thread
Old 23-09-2009, 08:28 PM   #11
au11futura
au11futura's Avatar
thanks for that..
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 13-11-2009, 06:50 PM   #12
Halfmo Rocks
Bearded Hermit
disable the lights...so they would be on - like a warning light unless disabled?
i have a line on an XR cluster & am keen to do this
Halfmo Rocks is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2009, 09:24 PM   #13
Tors77AU
NEED MORE CASH *** ***S!
Tors77AU's Avatar
Ok, ive got an AU series 1 forte, and i plugged in a series 3 fairlane cluster and everything worked minus seperate door open function, the illumination and the dimming function.
In the docs on here and on ford mods it says that you have to change your oil pressure swith to a sensor, yet i get oil pressure reading on the gauge.
Guy that i bought it off used to work for ford a told me that all the AU oil senders where the same, just on low series when the voltage reaches a certain point it switches the oil warning light on.
Is this corect? seems to be the case with my 99 au anyway.
Tors77AU is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2009, 09:48 PM   #14
bodes-sh
has been mentioned a few times around here, au1's had a "proper" oil pressure gauge, that actually moved as oil pressure changed. au2 and 3 only had a basic one that would just sit sorta half way all the time, without actually measuring the oil pressure, so they just ran a normal oil pressure switch instead of a pressure sender...
hope that makes sense...
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2011, 05:05 PM   #15
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Old 25-01-2011, 06:11 PM   #16
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
did you heatshrink them yet?
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2011, 07:31 PM   #17
Uncle_Ken
Uncle_Ken's Avatar
Not Yet. Because I used the Floppy drive power cord going into the cluster I twisted and uesd electrical tape. No expossed wires any where. I will wait a few days to see if anything 'unplanned' happens then heatshrink them.
Thanks for your comments as I have done this job, it does help.
UK
Old 03-08-2011, 11:43 PM   #18
nuguy01au
Default Re: AU 2-3 High Series Cluster Upgrade
just wondering do you SWAP the pins over or move them into new position and remove other wires
also do i need the second connector for the cluster?
i have an au2 2001 with base cluster and replacing with a fairmont/fairlane cluster and need help. photos of before and after would be a huge help
nuguy01au is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2011, 04:07 PM   #19
Uncle_Ken
Uncle_Ken's Avatar
This might help you.
This is what I did with some pics. Its not a full how to however. Mine was an AUII low to high series.
http://www.fordforums.com.au/showthread.php?t=11319816
UK
Old 04-08-2011, 07:07 PM   #20
nuguy01au
aha now i got it am going to do it tonight see how i go
cheers
Old 04-08-2011, 07:45 PM   #21
Uncle_Ken
Uncle_Ken's Avatar
cheers
Good Luck, let the forum know how you go.
UK
Old 05-08-2011, 08:46 AM   #22
nuguy01au
yes it is in and workin just gotta get radiator coolant low light to stop flashin
Old 05-08-2011, 10:53 AM   #23
Uncle_Ken
Uncle_Ken's Avatar
Goo to hear, not had the radiator coolant low light to stop flashing issue (yet ) Post some pics of it in.
UK
Old 06-08-2011, 09:20 PM   #24
fourl6
AU Falcon Man
fourl6's Avatar
UK
iv seen it maybe twice in the 2+ years iv had the cluster in... doesn't stay on for long and i defiantly dont have a sensor.
One annoying thing i about a high series cluster and low series dash it you lose you DTE, but it still beeps at 80kms to empty every time you start the car etc you just cant reset it (you have to wait for it to finish beeping, which feels like 5 minutes)... the fix for that is to fit a high series dash
Cheers Cam
Was
Old 07-08-2011, 09:30 PM   #25
nuguy01au
dont really want dte anyway
the low washer level light disappears but not the low coolant level light. a sensor needs to be fitted in the car somewhere to stop it
Old 08-08-2011, 09:09 PM   #26
FGII-XR6
FGII-XR6's Avatar
you can download a doc with all the required pinouts from my server http://www.hunterit.net/cluster.doc
if you are using a S2 or 3 cluster don't change the oil sender
[SIGPIC][/SIGPIC]
Rides:
Old 08-08-2011, 10:33 PM   #27
fourl6
AU Falcon Man
fourl6's Avatar
you still get the dte beeping, just lose the ability to view the kms and stop the beeping...
Was
Old 11-01-2012, 10:50 PM   #28
BadTruck81
"Layin Frame"
BadTruck81's Avatar
Did you get the low coolant light off mate as i have the same prob and cant get rid of it????
BadTruck81 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2012, 11:25 PM   #29
nuguy01au
i went and bought new coolant bottle and sensor and fitted it in had to do bit of homemade wiring cause didnt have the plug
Old 11-01-2012, 11:49 PM   #30
BadTruck81
"Layin Frame"
BadTruck81's Avatar
Where did you tap in the wiring???
