14-10-2014, 06:31 PM | #1 | ||
I had a dodgy IAC valve replaced and the car started moosing horribly.
At 100 Kph it was just like a foghorn continuously blowing. I found a fix on the web and it worked perfectly, even if was for throttle hang. Check it out. http://www.contour.org/ceg-vb/showth...ottle-Hang-Fix BTW I used a 20mm end cap with a 6mm hole. Cheers Todd |
