Old 05-05-2013, 04:38 PM   #1
mexicov
Default ZF 6HP26 Coolant bypass
Hi. New to AFF - bear with me. I have a 2010 FG XT, 6 speed auto. Warranty expires in two months. I travel a short distance (2 km) to work in freezing Canberra winters so transmission would not fully warm up. I am looking at using a PWR air/oil cooler to bypass the standard Ford transmission unit and avoid the "Milkshake" problem.
1. Has anyone had very cold weather (down to -8 deg) experience using the air/oil cooler? -over what time frame (years)?
2. If so, has there been any ill effects on the ZF 6HP26 transmission.
3. If I DIY, avoid any spillage, then totally fill the cooler and lines with the correct fluid, do I need to have a specialist go through the procedure for "topping up" the transmission? (Car has done 65000km and I was hoping to leave this until I have the transmission filter changed at 80000km).
Any advice would be appreciated. Thanks.
mexicov
mexicov is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2013, 04:40 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: ZF 6HP26 Coolant bypass
Try posting this in the "F6, XR6T and G6ET" forums. You'll get more responses there in regards to aftermarket ZF coolers.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2013, 04:50 PM   #3
mexicov
Thank you. I will work on a way of entering that thread.
mexicov
