20-04-2023, 09:50 PM | #31 | |||
Regular...with metamusal
the fuse your referring to is listed in the owners manual as fuse 6 - so looking at the dash fuseboard it is the 6th fuse from the left on the lower line of small fuses. the one i referred to is fuse 28 - the 3rd from the right on the top line of small fuses. |
07-06-2023, 01:49 PM | #32 | ||
I'm so glad this exists, Because now I'm having this damn issue.
However I'm using the Areopro facia with double din unit and every single fuse is completely fine. Tested a few pins in the main plug for the unit and power is there. I also plugged the old original ICC which worked in and nothing. I've never been so confused in my life. Especially that it was working the day before, then started the car next morning and absolutely nothing on the ICC working. Absolute electrical nightmare. This is such a painful issue. |
11-07-2023, 06:14 PM | #33 | ||
My ICC currently goes black. Have audio, screen only turns on as car is turned over or pwr button pressed or changing volume. Havent checked AC controls.
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
11-07-2023, 07:58 PM | #34 | |||
should switch back.
FGII XR6 IN LIGHTNING STRIKE R52 SIII IN GUN METALLIC |
12-07-2023, 10:22 AM | #35 | ||
Thanks mate, ill give it a whirl
12-07-2023, 03:38 PM | #36 | ||
Worked. Thanks. What happened though?
12-07-2023, 03:43 PM | #37 | ||
Hi. Holding down the power button for more than 5 seconds turns on/off the screensaver function. It gives you better night vision when the lights are off when you are at the drive-in. Cheers MD
2 users like this post: |
12-07-2023, 03:44 PM | #38 | ||
Its a feature. I do use it if for example doing a long trip at night on un lit roads. So to turn this feature on/off you hold the power button for a few seconds. Every time you make an input the screen will turn on for 5 or so seconds then back off again. So your icc is not faulty, its just a feature.
12-07-2023, 09:56 PM | #39 | |||
cheers |
