28-03-2011, 09:29 AM | #31 | ||
Chilli Orange
I have had a car with a Space Saver before, and I am just sick of having to change a tyre twice when I get a puncture.....
So, prefer the alloy. But, if it doesn't come easy, then a steel will have to do. Definitly not going to buy it from ford. I will be keeping my eyes peeled at wreckers for the same ones I have. |
01-04-2011, 09:03 PM | #32 | ||
Now that i've got a spare in the back, there's no where for me to put the air pump, jack, towing eye and wrench, so i put it all in a big plastic box i carry around in the back.
Now when i go around corners, i just hear it thumping around in the back, which is not encouraging... So how do you guys manage your mic tools in the back with a spare tyre? |
01-04-2011, 10:22 PM | #33 | ||
You can get a foam insert from your Ford dealer for $26 and this is for the Fiesta and fits neatly over the ridge in the wheel well. Holds jack, wheel brace and towing eye plus you can squeeze the petrol filler funnel under the brace. Keeps everything from rattling around!
Unfortunately the WS tie-down per Ford dealer does not reach the hole because the tyre is a 185 and I presume this part was made for a 175 tyre. However I have a Focus part coming next week that I think will fit and if it does I will let you know the part no. (See attached photos of the foam insert) |
01-04-2011, 10:28 PM | #34 | ||
Forgot to mention in reply above that the jack is from a Ford Ka which fits the sill of the Fiesta and I got in unused condition from a breakers yard.
02-04-2011, 01:56 PM | #35 | ||
damn :(
I'm using a bottle jack i got off SuperCheap and my spare is flipped upside down, so the outside of the tyre is facing down. But might see about playing with spare bits of foam or even rags. |
10-04-2011, 06:20 PM | #36 | ||
So here are a few pics of how it fit together.
Also, just wanna ask whether those nuts for alloys will work for the steel rim? The guy i bought the lock nuts off said they'll be just fine, but it just sounds a bit dubious given the taper on these bolts. Last edited by Caydus; 13-04-2011 at 10:54 PM. |
10-04-2011, 06:38 PM | #37 | ||
The wheel nuts with my alloys might work on the steel rims if you dont drive over 20km/h and not more than 10kms........... i got the spare wheel nuts off the steel rims when i got my car from Ford for that reason.......... I am selling the steel rims with original wheel nuts and plastic dress cover for $20 each if you are interested....... pick up from Blacktown or Homebush in Sydney or courier at your costs...........
Capri Car Club of NSW,
Keeping the Legend Alive since 1985 |
10-04-2011, 08:24 PM | #38 | |||
All Philippine spec Fiesta models come with a spare tire on 14 inch steel wheels. I believe the jack and other tools should be under the spare wheel which is secured from the center. Last edited by AG3; 10-04-2011 at 08:40 PM. |
11-04-2011, 09:49 AM | #39 | |||
Chilli Orange
If you use alloy nuts on the steel wheel, the wheel will be able to move concentrically onto the stud threads. i.e.using Alloy nuts on Steel wheels will cause thread damage, and also not allow the wheel to stay centered. |
11-04-2011, 12:14 PM | #40 | |||
Chilli Orange
11-04-2011, 03:20 PM | #41 | ||
Sorry, no tyres.
For $20.00 each plus wheel nuts and dress rim you are getting a pretty good bargain, you can pick up a fairly cheap tyre for $50........
13-04-2011, 10:56 PM | #42 | ||
probably going abotu this the wrong way but I too am after a spare to put in my CL wheel well or even just in the boot incase of emergency. Have a jack too, whats the best way to go about getting a spare CL tyre?
Suggestions anyone? Or just troll the bob-janes asking if theres any spare tyres around? |
13-04-2011, 11:00 PM | #43 | ||
In my experience, alot of wheel/tyre places don't have 15" wheels with this particular bolt pattern, they would just flat out say no. It's annoying and a time consuming process to go looking for one at a random wheel place.
IMO, somer's deal is pretty damn good, $20 for the steel rim and the bolts. Just have a 185/55 cheap tyre fitted to it and you're good to chuck it in the back. I'm not going it for it personally just cause i dont have anywhere to put the rim and don't really need it anymore. |
13-04-2011, 11:06 PM | #44 | ||
yeah i might just wait a few months till i chuck a full new set of alloys and tyres and buy an extra or something... sell my cl tyres and wheels to needy owners, lol!
07-05-2011, 06:55 PM | #45 | ||
I'll have some CL steel wheels/covers (15's) to get rid of shortly if anyone is interested. (In Brisbane).
Like the other seller - $20.00 each. Just PM if interested. |
23-06-2011, 10:44 AM | #46 | ||
Chilli Orange
OK, all that stuff up above about requiring different nuts for the steel wheels...
Load of croc! Sorry to put everyone off the track. But I have now got myself a spare wheel, jack, and brace. The nuts from the wt fiesta are a tapered nut, so actually also fit the steel wheel. It's actually a two part nut, that allows the tightening bit to turn while the taper bit embeds on the alloy but does not rotate. Jack and brace i got from a local wreckers for $25. The jack slot fits over the front seam nicely but have to put it next to the rear seam. Can also confirm the following for a WT Fiesta hatch: - it is 4 x 100 - Tyre dude said that this PCD is much more common for after market wheels than the 4 x 108 - Probably why Ford changed. - full size 185x55 R15 fits in the wheel well, and the boot trim sits down perfectly. - The Contis that come with the car are 86 rated, and 86's are few and far between. Quote for a spare Conti (Tyre only) was $225... Ouch. Still on the look out for one standard WT LX alloy and some way of fixing the tyre in the wheel well. Junkie. |
23-06-2011, 12:02 PM | #47 | ||
Shortly after this thread drew to a close I did get a spare wheel. A spare steel rim with a stock conti tyre, did about 7kms to get from the dealership to the tyre place.
I know, not the best deal but was fed up and wanted it over and done with. Sits in the well fine. But it does sit high and lifts the boot floor about 2cm higher than what it would usually be. Placed it in "inside up" and ford had a bolt with a plastic washer made up during my 1500km service. Got some free nuts from a mechanic friend. |
08-08-2011, 12:51 AM | #48 | |||
Will let u know! |
08-08-2011, 01:14 AM | #49 | |||
Fixing Ford's **** ups
I know this is a late posting by me, but this quote is a load of crock. Providing the tyre hasn't been run flat, all that is required is the gunk washed out (whole 5 minute job) and the hole repaired. Then the tyre is perfectly safe to drive on. Oh and cost is the cost of a normal puncture repair. For what it's worth, I reckon they should ban this gunk crap. It can be dangerous driving on a tyre that has gone flat and not inspected internally prior to re-fitting
02-02-2014, 03:36 PM | #50 | ||
Help please,
Will a 16 inch wheel fit into the fiesta WT ZETEC diesel wheel well?. If so where can one be purchased? Where can a suitable jack etc be purchased. I travel mostly on the highway and often after dark. Don't feel safe without full sized wheel as spare Any advice please. Have been told a 14 inch is ok. i don't understand how this could be Donna |
03-02-2014, 10:59 AM | #51 | ||
Wow, where has this thread been mined from!
There is some seriously bad info in here, a bottle jack in a fiesta is useless, there is four points for jacking on a fez and fiestas come from factory with the specific jack that is required to fit those points and bear the load, fiestas have always been like this, had my first one, an mk3 model 10 -15 years ago, had same jack and jack points, mind you the spare sat under the car on that model. The rubbish about nuts not fitting, is a joke, alloy nuts fit steel wheels but will usually not work other way around due to the recess's in the alloy wheels where the nut goes, you might find that the factory wheel brace may not fit aftermarket nuts! Donna, the 14" space saver you have already will do fine, the jack and wheel brace should be located underneath the wheel, in the wheel well. If not go to a wreckers and get one out of a wrecked fiesta or Ka, The space saver spare wheel is a temporary fix, designed for weight saving, = better economy, and as long as it's on the car you will remember to get the punctured one repaired. I have seen it happen on more than 1 occasion in the past where a mate who carried a full size spare alloy which matched the rest, gets a flat only to go to the boot to find that he never got the last puncture repaired, as put it in and forgot about it! And another thing before you bother yourself with this trivial matter, How many punctures have you got in the past, and do you have a phone number for NRMA!!! She'll be right!! |
03-02-2014, 02:14 PM | #52 | ||
Thank you Dreadly ST for your advice.
The whole wheel thing is an issue because I live in a rural area and travel a highway to and from work often late at night. Don't want to get stuck having to do 80 kms going to and from work at 10 pm (round trip is 90 plus kms to work and back). I believe a 15 inch steel with a tyre to make up some of the difference and placed on a rear wheel will allow travel at 100 kms to give me time to have punctured one repaired (and will fit in wheel well). I don't understand why manufacturers cannot provide better options. Not everyone lives 5 mins from a repairer. You are right about the punctures. Have had only 2 in 10 years. Now I no longer live in the city the thought of a puncture at midnight on the highway in a rural area is a worrying one. Belt and braces approach. Cheers Donna |
