08-12-2017, 09:33 PM | #1 | ||
Hi all.
Interesting one here- I have a mk5 cortina ghia. It has two interior ceiling courtesy lights. Both have the on-off-door setting. But the door setting doesn't seem to work. The bulbs are fine because they work when switched to on, I have cycled each door switch but no result. Any ideas of why the door setting isn't working?? |
09-12-2017, 07:55 AM | #2 | ||
The usual cause is that one of the actual door switches is either jammed in the off (closed) position or the wiring to them is damaged.
Cheers Russ
