21-03-2006, 07:16 PM | #1 | ||
Location: Under the bonnet, trying to keep as clean as above!
hi all was just wondering if you can buy the whole rocker assembely for the 4.0l. and if there are any performance items out there for it. thanks heaps pete
21-03-2006, 07:59 PM | #2 | ||
The standard stuff is as good as it gets. The only thing you could look as is using late ED - early EL rocker gear.
21-03-2006, 08:42 PM | #3 | ||
yer go to you'r local ford wreaker and thay should help u out with wut u need
thay probally sell them less shim's and lifter's so you'l have to pay extra for that id say preformance not much for impproving ther all ready roller rocker's but id got n e thing later then eb1 |
21-03-2006, 09:10 PM | #4 | ||
thanks for that guys. it's just that the valve blew the lifter straight through the rocker so i gotta get a new one. plus it had a ticking noise around 5 and 6 and i heard that that is because of the rockers cutting a groove into the shaft they run on. is that true?
22-03-2006, 09:56 AM | #5 | ||
PM me if you want
You can bolt ef/el rocker gear straight onto any 3.9L/4.0L block, no difference, just newer, slightly better design and hopefully no lifter ticking.
Also you can mix and match EA and EF/EL complete rockers (with a little bit of modding when you get stuck )
22-03-2006, 10:49 AM | #6 | ||
What Wheelspin?
geez, my lifters are noisy as some times. does this mean my rocker gear will soon be f##ked?
i have also had a really loud lifter noise on start up, that goes away after 10-30secs or so. what could this be?
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
22-03-2006, 11:18 AM | #7 | |||
White Lightning
22-03-2006, 11:20 AM | #8 | ||
PM me if you want
there is a product that is supposed to help fix noisy lifters, from what i have seen on the forums those that have used it, have been happy with the results.
22-03-2006, 11:27 AM | #9 | ||
BASS ON BOARD!
Valve guide seals? more oil? thicker oil? oil additive?
Nothing interesting to put here. |
22-03-2006, 03:22 PM | #10 | ||
ther resson u'l b hearing a ticking noise is because one of you'r liffer's is dead
it makes the noise coz he lifer wont hold compression n e more (oil not geting up ther) i no i got one:( but do an oil change and that might help with the ticking |
22-03-2006, 03:48 PM | #11 | ||
also a trick for young players... ea-eb series 1, and very early series 2 have 14mm lifters...
from then on, remainder of series 2 eb's onwards to el have 11mm lifters... found this out when i ordered Rollin some after i got mine... i had 11mm, but Rollin (Series 2 EB XR6) had 14mm lifters.. i have 11 new 14mm lifters for sale if anyone is interested let me know... ford want $50 each, i will take $15 each... they are brand spankers...
Powered by Rollin Motorsport Turbo Barra ED 4L
22-03-2006, 06:42 PM | #12 | ||
thakns guys. i'll check me lifter size paul. i'll probably need new ones so i'll take em if there the right size.
