18-01-2008, 11:33 PM | #1 | ||
Sly like a G6
Got a cruise control module, wiring, switches, yoke etc from the wreckers. Fitted it today while I was fitting the new Momo wheel. On testing it, the stalk turns the "Cruise" indicator in the odometer panel on, but the steering wheel buttons don't work... it won't set a speed. All the wires are connected up OK, as is the cable to the throttle.
What I don't have is the braking module to screw into the master cylinder, so its electrical plug is just sitting there unconnected. Do I need to have the braking module connected to set a speed or should I also be looking elsewhere?
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
19-01-2008, 01:24 AM | #2 | ||
Sly like a G6
Dig around in enough manuals... I'd been under the impression it was a fancy way to apply the brakes to stop speed creeping up while going downhill... turns out it's a pressure switch that open-circuits when the brakes are applied, cancelling the cruise setting. No switch, permanent open circuit, no cruise. So back to the shop to get the missing part...
19-01-2008, 12:40 PM | #3 | ||
formerly PURSUIT-250
Yes this is correct, you need the switch for it to work also fit a new one they tend to play up.
19-01-2008, 09:09 PM | #4 | ||
Sly like a G6
Yup, fitted a new one today, all good now. Will be handy coming home from dogwatch over the long weekend with double demerits...
20-01-2008, 01:04 AM | #5 | ||
Sales Representative
How much did you pay in total for the parts?
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
20-01-2008, 11:31 AM | #6 | ||
Sly like a G6
$165 from the wrecker for CC module/cable/fittings, wiring harness, combination switch assy (steering column stalks), steering wheel switch and anything else I forgot.... everything except the de-activate switch. The de-activate switch cost $38.90 new from Ford. So all up $203.90.
Standing on my head under the dash to install the wiring.... priceless!
23-11-2009, 02:14 PM | #7 | |||
Treasure your balls?
Meteorite T3 TS50 ESS |
23-11-2009, 02:38 PM | #8 | ||
Rusticating
For the record, I believe it's also possible to bridge the pins in the socket, though I haven't tried it myself. I think that switch is just a backup for the brake pedal switch.
Territory SYII RWD, BFII RTV tray |
