Hey guys,
My neighbour recently replaced his Holden with a Ford XR50, and I really like the wheels he got with them. I can't find them on the Ford website, does anyone know where I could look for them? Also, how much would I expect to pay for them (17"/18") with tyres? I'm assuming "too much" but I thought I'd find out anyway. The pics are what they are when I've roughly photoshopped them onto my car. Also, can anyone explain to me what offset wheels are and how they differ from non-offset? I've been reading it everywhere and I have absolutely no idea... Cheers. |
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
IIRC I was quoted something crazy like $2500 for a set through ford for the "standard" xr8 rims. I dont think anyone will have them for sale for a while, best bet is ebay.
I could imagine a price around $3-3.5k from Ford, just because they can and they are brand new. You could probably buy a set of normal XR8's and powdercoat them for alot less.
Yeah..okay...thats a bit much. I had a feeling it was going to be something outrageous. I've got a 2000 AU2 Fairmont as well, Polyal. What have you done to yours in terms of visuals (I'm a P-plater for a while yet, so i'm not really bothering with performance stuff)? Any photos?
#4 | |||
Virtuous Bogan (TM)
I was once in your positin but now a young family man so I dont mod my daily like I used to, but I have done a couple of things. If you look in the AU Build section there is a thread there, I like you went with some FG rims but chose to go the G6E route.
AUII XR8, BA XR8 290 UTE
they pop up on ebay from time to time from a grand and upwards..
AUII XR8 220 Build : Blown 380HP 810NM - http://www.fordforums.com.au/showthread.php?t=11253752 BA 290 XR8 Ute Build -http://www.fordforums.com.au/showthread.php?t=11271242 |
![]() Join Date: Nov 2007
The Monty
i can get u a set of 5 with no tyres for 1100 orginals 2
Sweet cheers guys, I won't have enough money until next year haha oh well.
I spoke to a guy at FDO in Ferntree Gully and he says they can get me a set with tyres in "very good condition" for 1 grand. He also explained what offset wheels were. Cheers again. |
The Monty
au - fg have same off set +8 ( i think)
eb - ef have same of set (i think) not much else u need to know |
#10 | |||
Owner of "0066" F6 310
AU onwards falcons used a FWD offset for the rims and at the time this opened up a larger range of wheels than what was then available to the older EL and previous models. |
pursuit ute baby
oh man.. you guys have no idea..
offset is the specifics of the rim, not the car model. offset refers to how far from the hub (where wheel ataches) to the centerline of the wheel.. its either zero, positive, or negative. so +35, or say -8. once you get to negative, you are looking at some pretty serious wheels, where ull most likely have a very concave face, alot off dish, and the wheel hanging out of the guards. pretty common with jap cars to try and have low offset wheels for better 'track'... which is the stance between the tyres (distance). -edit- found a pic to make it clearer for ya's.. ![]() |
#12 | ||
Should of posted that in the wanted section, or cant you due to the post limit, if thats the case, mods should delete this
#13 | |||
Whilst offset is a term in relation to the wheel, the fact is that offset is car/model specific. You cannot fit AU and later wheels onto an earlier model. |
#14 | ||
In them style or rims the XR50 as you call it (even though those rims were on the XR's before the 50th anniversary edition's).
You can have the style with silver paint and machined metal, the XR style. Then there's the XR50 edition which is the same rim but the painted section is a gun metal grey colour! The XR50 edition's are available as a XR6, XR6Turbo, and XR8 in both sedan and ute. They are a 18x8" rim with a +36 offset as all late model falcons are.
****el's drive Rotaries, Four in-line is a waste of time, Six in-a-row just won't go, If you really want something great, drive a great big Ford V8! God made Holden's to keep w*****'s out of Ford's, and yes I'd rather push my Ford than drive a Holden! |
#15 | |||
pursuit ute baby
you are thinking of the stud pattern, more specifically pitch circle diameter (pcd). Any offset wheel can be made to fit any vehicle (within reason), but rolling or flaring of gaurds would be required if the wheel is too wide, or in extreme cases, tubbing is implemented.
my ride : AU xr8 pursuit ute ![]() |
#16 | |||
Any offset wheel cannot be made to fit any vehicle. Try fitting an 8" rim from an X-Series to an AU and let me know how you get on. You'll need to do a little more than guard rolling. Conversely try fitting an 8" rim from an AU onto an X Series - beleive me all the tubbing in the world will not make them fit. Although you could fit hub adaptors. |
