Go Back   Australian Ford Forums > The Sales Yard > Cars for Sale
Cars for Sale Complete or nearly complete Cars for sale. Note: ALL transactions in these forums are done at your own risk. FordForums Australia Inc. does NOT take responsibility for any aspect of any item or transaction that may take place via the site.
Old 30-04-2024, 09:31 PM   #1
onemanempire
One Man
onemanempire's Avatar
Default (SA) Ford Futura Series II 2004
Vehicle Sales Form
State : SA
Make of vehicle
: Ford
Model of vehicle
: Futura Series II
Year of manufacture
: 2004
Colour of vehicle
: White
Engine
: Barra 4.0L
Transmission
: Auto
Body style (sedan, wagon etc.)
:Sedan
Selling Price $
: 4600
Odometer Reading
: 241241
City
: Direk 5110
Other relevant information.
Hi guys and girls, I am selling my 04 BA Futura as I have upgraded to an FG-X falcon.
I have owned the car for about 8 years and in that time have done many things to it.
I will list all of the things I have done $$$ at the end of this listing..
$4600 Offers considered when made in person.
Ba Falcon (Futura) series 2, 4 litre 4 speed Auto.
Rego expires 1/06/24
Have upgraded to a FG-X.
The car is clean inside and out. The paint is good.
It has NO towbar or LPG, serviced every 10,000kms or sooner (oil and filter Nulon 15w - 30 Full Synth).
The car is clean and drives perfectly.
The car is smooth at freeway speeds.
Everything works as it should A/C, heater, electric windows, cruise, wiper washers etc.
Has a kick a-ss sound system.
Would suit fussy buyer... as I am a fussy owner.
Below is a list of things i have done to this car in the 8+ years I have owned it:
F6 airbox upper section. Looked good so I thought WOT the hey.
Transmission cooler fitted when I purchased the vehicle
Coil packs replaced @ 165kms
Spark plug seals, spark plugs (NGK Iridium) and rocker cover gasket replaced @ 199kms
Coolant changed and flushed, refilled with 8 year coolant and demineralised water @(165kms)thermostat gasket replaced at the same time
New battery 9 months ago
Windscreen wiper heads replaced 170 kms
Windscreen washer jets replaced 175 kms
Windscreen replaced (170,000kms)
Kenwood sound system, sub + 5 channel amp and 4 new Kenwood speakers
Fitted Fairmont Ghia dash spears (woodgrain)
Fairmont Ghia leather steering wheel
Led interior light
Tinted the windows and fitted a rubber stick aerial to improve radio reception after tinting the windows.
Replaced 3 central locking door lock actuators Front RH, LF, RH Rear
Replaced all window switches with illuminated switches (Fairmont Ghia spec)
Replaced front tyres 1000kms ago (rear tyres around 50% tread)
Replaced all 4 front ball joints
New front rotors, Pedders ceramic dustless brake pads, and brake calliper slide pins (2000kms ago)
Rear brake pads changed about 6 months ago (Pedders ceramic dustless pads)
New Pedders rear shocks about 6 months ago
Sway bar "D" bushes replaced (Front)
Serviced the transmission @ (175,000 Kms) Filter and fluid
Replaced rear seal on transmission, had a slight weap
Tailshaft pilot bush replaced along with centre bearing and universal joints
Intake manifold gasket replaced
Magnetic sump plug fitted - engine-
Diff oil changed at 200,000 kms
High pressure power steering line replaced
Serpentine belt replaced
Bonnet gas struts replaced
Boot gas struts replaced
Rear upper rose joints replaced (Left and Right)
Ignition barrel repaired....
Everything works, heater, cold A/c, Electric windows, door locks, lights etc.
It does not leak a drop of anything fluid wise.
Doesn't use any fluids.
HSV, I just beat one
onemanempire is offline   Reply With Quote Multi-Quote with this Post
