Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
01-05-2024, 11:15 PM | #1 | |||
AXLE ASSY - REAR, WITH M86 SERIES AXLE, TAG ID:8R29/G* (4.0 DOHC PETROL EFI TURBO 24V VCT, AUTOMATIC TRANSMISSION, 2.73, REAR AXLE LESS LIMITED SLIP DIFF, 4 WHEEL ANTI-LOCK BRAKING SYSTEM) or FG Ute From 8/12/2010: AXLE ASSY - REAR, 1 TONNE, WITH M86 SERIES AXLE, TAG ID:8R29/G* (UTE, AUTOMATIC TRANSMISSION, 2.73, WITH EXTRA HEAVY DUTY SUSPENSION, REAR AXLE LESS LIMITED SLIP DIFF) |
03-05-2024, 08:32 PM | #3 | ||
Looking for the below FG items:
The black outside door mouldings complete set for front and rear doors. RH/LH interior seatbelt B pillar trims in black. |
03-05-2024, 09:52 PM | #4 | |||
When you say Seat belt b pillar trims I assume you refer to the top half, not the bottom half. For the top half FG1 and FG2 only came in light cashmere, FGX is the only one that also came in Light Limestone & Shadow Grey which is not quite black, but closest too. From what I think you can only get LH one only (need to confirm if any left), RHS is obsolete for sure for Shadow Grey Light Limestone is all obsolete too. . |
03-05-2024, 10:21 PM | #5 | |||
Yes the outside door moulding for FG MK1. Seems I can find these online apart from the RL door mould? I have everything to blackout my FG MK1 but just require the top seatbelt B pillar trims to complete my set. Everything I have is from a FGX which would be shadow grey. |
03-05-2024, 10:30 PM | #6 | |||
I would need to check but for FGX I think only the LH B pillar upper trim in Shadow Grey is available. |
03-05-2024, 10:33 PM | #7 | ||
