11-08-2012, 12:23 PM | #151 | |||
It will run lean if you use a bigger t/b and maf. It is on the limit for the standard eb tune though because ive had mine on the dyno and its around 13/1 afr although ive never had it ping on me using 98 octane. The guy who dynoed my car told me it will be fine for everyday driving and the odd blast down the drags but refrain from doing burnouts. Almost 30000km down the track ive had no issues and ive been to the drage 3 or 4 times. |
13-08-2012, 12:13 AM | #152 | ||
90mm lightning maf on eBay from America mate if you want one cheapest I've seen
13-08-2012, 01:18 AM | #153 | ||||
Cocoloko
In saying that the crane ones where made specific for Ford, so maybe thats why there the 1.6's and not avliable in the crane catalogue...
94 ED XR8 Sprint: SVO alloy heads, FMS F303 cam, AU EECV ECU, T5, on going build. 2010 Territory: family bus. 79 P7 LTD 351. |
13-08-2012, 01:44 AM | #154 | |||
Boost is here!!
http://www.summitracing.com/parts/FMS-M-6564-A50/
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
13-08-2012, 03:47 PM | #155 | |||
Cocoloko
Was looking at a set of them just the other day too lol.
12-09-2012, 08:59 PM | #156 | ||
Hi there people, been a while since I was on here...
Have a question, I have a 11/01 build AUII XR8 ute,, I have had valve train noise for ages... Long story short, i pulled the rocker covers off today and found a broken valve spring... Howver the suprising part is that It has Yella Terra Roller rockers and double valve springs. Does this mean it is a 220kwe long motor? OR are all 200kw valve springs double and i just lucked out with some 220kw rockers? Heads are cast iron. Basically with the engine open how can I tell which long motor it is? Throttle body has no wings and there is no oil cooler... Need to know because i want to order a spring thru Ford..Thanks fellas |
14-09-2012, 10:07 AM | #157 | ||||
Back to Le Frenchy
14-09-2012, 03:47 PM | #158 | |||
5.6L x 2 pilot
Do you miss your AU Russ? Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
14-09-2012, 06:51 PM | #159 | |||
not here much anymore
RAM 1500
10-07-2013, 06:43 PM | #160 | ||
Yeh hi
ive been looking for a straight forward answer on engine no"s I want to know with out looking @ pages after pages of total ******** What are the start off LETERS & NUMBERS A HAND BUILT 220kw ENGINE |
10-07-2013, 07:30 PM | #161 | |||
The VIN number will not necessarily identify a 220 engine - you need to check a few things on the engine to know for sure. But you know what - read the above mentioned 'pages' and find the answer yourself.
RAM 1500
3 users like this post: |
11-07-2013, 01:56 AM | #162 | ||
Sorry if im missing something
6 years of uni and the last 20 year A marine enginer its the 1st ford ive owned & through & through im an GM FAN the trouble ive had with everything ford LOOKS LIKE I CAN HEAR THE CALL OF THE LION "S RAWwwwwwww & ITS BACK TO HSV FOR ME !!! |
11-07-2013, 10:04 PM | #163 | |||
Enjoy your commodore.
RAM 1500
14-07-2013, 08:04 PM | #164 | |||
15-07-2013, 01:41 PM | #165 | |||
Back in black
Black Mac TE50 S3 NO: 106 Little Mac AU S2 XR8 Bite the snake before it bites you! ______________ _.__ /________...\ _.._(___\\___//___) .._..(O...\____/...O) |
15-07-2013, 06:52 PM | #166 | |||
My Ride... 2005 BA2 XR6 Magnet Ute. |
15-07-2013, 06:59 PM | #167 | ||
5.6L x 2 pilot
Ok Gents. This is not a newbie, GM or grammar bash thread. Points have been made, let's leave it at that. Any further posts having a shot at the iceman post will be deleted.
15-07-2013, 07:02 PM | #168 | ||
Very true...My apoligies.
14-08-2013, 03:03 PM | #169 | ||
3..2..1..
Were xr v8 engine numbers different to none xr?
Just trying to work out if my lane has had a xr motor or something done to it. Doesn't have any of the external clues, like the ticky tb or anything like that, but it just seems to go really well for what should be quite a 'sedate' big old car. |
14-08-2013, 05:24 PM | #170 | |||
Stay Classy ™
Engine number should match VIN number. If they don't, motor has been swapped out at some stage. |
14-08-2013, 09:51 PM | #171 | ||
3..2..1..
Of course, I never thought of that, il check it in daylight tomorrow.
02-11-2013, 03:33 PM | #172 | ||
Isn't it obvious?
ok so this is in an au 5 litre from a fairmont ghia someone tell me something about it would be 175kw? although it does have 3 inch and cold air induction fitted cheers
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens |
02-11-2013, 06:06 PM | #173 | ||
Stay Classy ™
Yes, it's a 175kw motor. May have a little bit more power with the mods, but all Fairmont Ghia's had the 175 motor
19-01-2014, 08:33 AM | #174 | |||
MoPar man 11
and has the oil cooler.. and 3.5 inch behind airbox and a 70ml TB (NO WINGS EITHER) and a dotmax windscreen and clear side indicator lenses and colour coded mirrors so Im upset now to read FORD just threw whatever they found on it... What a bitsa |
19-01-2014, 08:35 PM | #175 | ||
My au 11 xr8 pursuit ute also the 1.72 yella terra rockers, doesnt have the factory c & c ported heads like the 220, the part number on the cam indicates its 200kw spec cam shaft and it doesnt have the tickford throttle body. odd....
19-01-2014, 10:36 PM | #176 | ||
Not as odd as you might think, I've had 2 XR utes like that now, both were series III and NOT 220's!
RAM 1500
19-12-2014, 11:29 PM | #177 | ||
Irregular member
I was wondering if anyone has an an AUII Windsor V8 engine bay diagram of what's what? So I can locate all the components and know what they are before I remove an engine and put it into another engine bay. Thank you...
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
15-12-2015, 05:57 PM | #178 | ||
I ♥ EDM
Bit of a threadmine here, but am needing some confirmation on the AU2 sedan 200kw motor;
- Crane 1.6/1.7 RRs - E303 Camshaft - Headers & Exhaust - Regular 175kw TB |
15-12-2015, 06:45 PM | #179 | ||
09-02-2016, 09:48 AM | #180 | |||
R.I.P. Maggie
i was just looking at this old thread, I just got a 11/01 xr8 ute, thimking it had the spacer it was a 185kw, but reading this it coild be a 200kw. I havent called ford yet, but is it possiable it is 200kw Thanks |
