09-12-2021, 08:34 PM | #1 | ||
I have a 2009 Fiesta Zetec, 1.6L Duratec engine.
I was hoping to rebuild it as a project. I have tried unsuccessfully to find a rebuild kit. Are these kits available in Australia. Any help would be appreciated. The engine has has a code of WF0GXXGA.
Fords I own or have owned: XW UTE, XW FAIRMONT, XT GT, XT Fairmont, EF XR8, XH XR8 UTE, XH XR8 UTE, AU UTE, Renault Scenic, XF UTE, BA XR8 UTE, TERRITORY, Chrysler Voyager, WS FIESTA ZETEC,TERRITORY TITANIUM, BA UTE, Nissan Pathfinder, AU Falcon Forte, BA XR8 UTE. |
09-12-2021, 10:46 PM | #2 | ||
I don't believe they are rebuildable. The WSM has this to say:
The crankshaft is attached to the cylinder block by means of a lower crankcase made of aluminum. This produces a highly rigid cylinder block. Never dismantle the crank assembly! Because of the very fine bearing clearance and bearing shell tolerances, components of the crank assembly cannot be renewed separately. Bearing clearance measurement (main bearings and big-end bearings) is not possible by traditional methods. The pistons are made of aluminum alloy and feature three piston rings. No oversize pistons are available.
09-12-2021, 10:53 PM | #3 | ||
Thank you Russell.
Off to the tip tomorrow/recyclers tomorrow and planning a new project. Thank you so much.
